Dyno resultswith 306 cam
Old Jul 24, 2004 | 07:02 PM
ftransam1's Avatar
Went to the dyno today and put down 314hp 336tq. Seems a bit low to me. What do you think???
95 firebird formula
ram air
stage I heads
cc306 cam
3.73 gears
headers/exhaust cutout
pullies
tb bypass and all free mods
stage II clutch
pcm for less tuning
anyone else with a 306 cam dyno results
Old Jul 24, 2004 | 07:11 PM
Valkyn71's Avatar
Re: Dyno resultswith 306 cam
Woah those are pretty low numbers for your setup.
How old is your Opti/plugs/wires/coil?
Also what kind of flow numbers did those heads make? I know people have made more power than that with the 306 and stock heads.
something is up!
How does the car feel? strong?
Old Jul 24, 2004 | 07:22 PM
Blue96z28's Avatar
Seems way low to me.....
Old Jul 24, 2004 | 07:24 PM
Somnambulist's Avatar
that really low...I barely have you on torque with stock cam and heads...
is the tuning for the 306 or did you have it before the cam?
Old Jul 25, 2004 | 02:19 PM
ftransam1's Avatar
Car runs really really strong and pulls hard. The motor is new and has 2500 miles on it. Plugs and wires are new as well as the opti. I just think the dyno needed to be re-calibrated or something because a friend of mine dynoed right around the same number with just bolt ons and I can beat him easy on the street. It was 96 degrees at the time of the dyno but it shouldn't affect it that much.
Old Oct 26, 2004 | 10:17 PM
ftransam1's Avatar
Update: I had a little valve and spring problem. So I fixed it a while back and I dyno 367 rwhp 382 lbft
Old Oct 26, 2004 | 11:25 PM
S8ER95Z's Avatar
There we go!!!!
Old Oct 26, 2004 | 11:28 PM
y5e06's Avatar
How did you determine you had a valve train problem?
Old Oct 26, 2004 | 11:57 PM
ftransam1's Avatar
Turns out the problem was me and over tightening the valves. I pulled the heads again to port out the heads some more because I was a bit conservative the first time and then re did the valves correctly. Had to get new pushrods cause two were slightly bent.
Old Oct 27, 2004 | 12:25 AM
TigerWoodsJr's Avatar
much better #'s.
Old Oct 27, 2004 | 03:00 PM
marshall93z's Avatar
definitely!!
Old Oct 27, 2004 | 03:07 PM
Alvin@pcmforless.com's Avatar
Good job
Russ95Z28
Apr 23, 2015 01:55 PM
racecarz28
Mar 30, 2015 09:55 PM
armedtrigger
Feb 24, 2015 08:30 PM
Kyle@CSS
Sep 14, 2002 04:06 PM
Grover
Jul 25, 2002 11:49 AM
