Dyno resultswith 306 cam
Went to the dyno today and put down 314hp 336tq. Seems a bit low to me. What do you think???
95 firebird formula
ram air
stage I heads
cc306 cam
3.73 gears
headers/exhaust cutout
pullies
tb bypass and all free mods
stage II clutch
pcm for less tuning
anyone else with a 306 cam dyno results
95 firebird formula
ram air
stage I heads
cc306 cam
3.73 gears
pullies
stage II clutch
pcm for less tuning
Re: Dyno resultswith 306 cam
Woah those are pretty low numbers for your setup.
How old is your Opti/plugs/wires/coil?
Also what kind of flow numbers did those heads make? I know people have made more power than that with the 306 and stock heads.
something is up!
How does the car feel? strong?
something is up!
Car runs really really strong and pulls hard. The motor is new and has 2500 miles on it. Plugs and wires are new as well as the opti. I just think the dyno needed to be re-calibrated or something because a friend of mine dynoed right around the same number with just bolt ons and I can beat him easy on the street. It was 96 degrees at the time of the dyno but it shouldn't affect it that much.
Turns out the problem was me and over tightening the valves. I pulled the heads again to port out the heads some more because I was a bit conservative the first time and then re did the valves correctly. Had to get new pushrods cause two were slightly bent.
racecarz28
Mar 30, 2015 09:55 PM
armedtrigger
Feb 24, 2015 08:30 PM
