Dyno results: post LT install
Old Sep 16, 2006 | 04:13 PM
CL21376's Avatar
soooo close to 300!!! My AFR is off (11.8 at WOT) so she should have enough in her to beat 300.
Dyno Run 1
STD 293.5/336.4
SAE 287.4/329.4
Dyno Run 2
SAE 291.6/332.6
Dyno Run 3
STD 299.1/339.6
SAE 292.8/332.4
AFR was between 11.7-11.9 the entire time.
Peak power was reached at ~5200 RPM
I guess Brian from PCMForLess is within 2 hours of the Dyno shop I used, and he will drive there if they have more than 1 car to tune. They already have a GTO lined up, so I'm the second car Should be there by the end of the month.
For comparison, I baseline at 271/315 bone stock (paper air filter, no free mods, stock exhaust i.e. not 2OTL)....different dyno though.
How much should I pick up if the AFR gets dialed in?? Maybe 10 HP??
Do these numbers seem good to you guys?
Old Sep 16, 2006 | 05:00 PM
96flame's Avatar
Re: Dyno results: post LT install
Great numbers and yeah get the A/F at 12.8 and you'll see the 300 mark.
Old Sep 16, 2006 | 10:48 PM
LT1 POWR's Avatar
If you can, get it tuned on the dyno. I made most power with my AF ratio at about 12.9.
I picked up about 15 peak tourqe and about 10 peak hp with just messing with the AF ratio.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
cheapchevy
Apr 8, 2015 08:48 PM
armedtrigger
Feb 24, 2015 08:30 PM
alex5366
Feb 17, 2015 09:07 AM
