Dyno results!!
Old Mar 5, 2003 | 02:04 PM
  #16
allmotorta's Avatar
Those are very strong numbers for just having a loudmouth. Niiiiiiice
Old Mar 5, 2003 | 02:05 PM
  #17
LimitedEd1LE's Avatar
Originally posted by Blk94Z28LT1
well, not sure about the loudmouth, but the tb bypass is good for 5 to 7hp, the underdrive pulley maybe 1hp, LT4KM, not sure maybe 5 to 10hp depending on the car, 160 stat, again not sure, let's say 5hp and the hypertech, well that's really a hot subject, but lets say 10hp. So on the low end maybe 26hp total, which would put you two pretty close. Just my 2cents.
Those numbers for those mods do not line up at all. Don't do the ricer math for calculating hp. The hypertech, 160 thermostat, and LT4KM will give u maybe 3 hp max. The only mod that is getting him HP is the loudmouth. The pullies suck, and the TB bypass maybe gives him a few ponies.
But I am very impressed with your numbers. Sounds like you have a healthy running LT1.
Old Mar 5, 2003 | 02:17 PM
  #18
camaroSSlover's Avatar
THANKS SLP
Old Mar 5, 2003 | 02:34 PM
  #19
Blk94Z28LT1's Avatar
It's not ricer math, if you read the boards most of these are proven on dyno's. If most people think that these mods aren't worth it, why do them. Just about everybody on this board have done these mods. As I said in the post, the hypertech is a hot subject, some people like em some don't. If you are getting alot on timing retard because of the knock module, i guarantee the LT4KM will make a difference.
Old Mar 5, 2003 | 03:42 PM
  #20
faded93bird's Avatar
man a 160 stat and a fan switch are priceless havent dynoed my car but they have helped tramendously in staying consistent with mph at the track which used to drop about 2 mph with each consecutive run now its pretty close that means im not loseing power due to heat soke
bye the way those are some good #
but if you like those saw a graph from a 96 ws6 that put down 306 hp and 330 tq at the wheels with nothing more than a cutout and a k/n through manifolds and no cam
Old Mar 5, 2003 | 03:52 PM
  #21
95 Silver TA's Avatar
Originally posted by IDOXLR8
Actually those are pretty impressive number for the mods you have.
EXACTLY!!!
Those are pretty good number for what you have done, throw in a good set of headers, a good y-pipe with high flow cats and you will be set....
Old Mar 5, 2003 | 03:56 PM
  #22
NiteRider's Avatar
It's just a very healthy LT1, must be a wednesday built.
Old Mar 5, 2003 | 04:06 PM
  #23
neil350's Avatar
If you think those numbers are bad, your smoking crack. Those are some damn good numbers for a car that still has stock exhaust manifolds, that LM is worth 10hp at the wheels max. That car is putting down some good numbers, very impresivemundo my friend.
Dont be mad cause you got the day after Christmass car Mines was built in Febuary, the interior sticker says the 11th so I'm sure the guy got dumped by his wife of 30 years right around Valentines day or was going through a nasty divorce.
Old Mar 5, 2003 | 05:34 PM
  #24
93ZM6Tally's Avatar
I will pipe in and say that those are very respectable numbers. Good Job!
Old Mar 5, 2003 | 05:43 PM
  #25
I only have 27k mi. on the clock maby thats why its so healthy
Thanks guys for the pat on the back
Old Mar 5, 2003 | 05:59 PM
  #26
SVT Killer LV's Avatar
my car did 284/325 with Hooker LT's.. you car is strong mine was a turd..
fift5
11
Oct 1, 2015 10:31 AM
HAWG
Sep 25, 2015 11:41 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
