Dyno numers for XE 230/236 with stock heads?
Old Feb 26, 2003 | 11:07 AM
  #16
RealQuick's Avatar
Originally posted by jonaddis84
I think everyone misunderstood his question. He wanted to know numbers with stock heads. From reading other posts, I would not recommend that cam with stock heads, unless you are going to port them in the near future, in fact you might not see much of an improvement at all with that cam and stock heads. That cam is a pretty extreme cam, made for well ported heads, if you have those its the best, but you want something a little more tamed than that for stock heads. Thats what I think.
My heads are homeported, and outflow stock slightly. I would think stock heads would yield similar results (gain of 50rwhp on pcmforless tune). Stock heads will be fine. Some people say the CC306 is too aggressive (and its bigger than the XE230/236), yet people with stock heads usually trap 112-115mph. No matter what LT1 cam that is no bigger than the 306 cam your gonnna gain serious hp.
Streetability is what he really needs to think about.
Old Feb 26, 2003 | 11:18 AM
  #17
jonaddis84's Avatar
I guess what I was actually trying to say is basically, that cam works BEST with pretty good ported heads. I think he would gain more from a smaller duration less lift cam on stock heads, since hes not flowing enough air to use up the duration and lift. I dont want to make this sound like Im an expert, Im basically just relaying info from other posts, I know nothing about this cam personally.
Old Feb 26, 2003 | 11:27 AM
  #18
RealQuick's Avatar
Its cool dude. Alot of what we learn are from other posts. If he is gonna do heads than go big, if not than staying smaller is fine. Results will be very similar. I just wanted to let you know 50hp gain I got.
Old Feb 26, 2003 | 11:29 AM
  #19
bunker's Avatar
Hehe as a matter of fact I'm doing this setup on my friend's car this thursday its a XE230/236 on a 112lsa, stock heads, stock rockers, comp 986-16 springs, K&N, Mac headers, new Crane lifters, & we're tunning it than going to a Dyno, so I'll post the results
Old Feb 26, 2003 | 04:01 PM
  #20
Momar's Avatar
I'd be interested to see how it does.
Ben
Old Feb 26, 2003 | 08:04 PM
  #21
mastrdrver's Avatar
The 230/236 should prove to have more gains than the cc305, hotcam, or xe224/230 bcuz
1) If used with 1.5 rockers it wouldnt have more lift than the stock heads can take. Stock heads will lose flow #s above .5 lift.
2) For the obvious reason that it has more duration than the other 3 cams.
I would suggest though that it be on a 114lsa to keep from having to rev the **** out of it to get max power and bcuz it will move the peak power down, compared to a closer lsa, and will make the cam more streetable.
Hey Joe, are you putting this in your car?
Old Feb 26, 2003 | 09:01 PM
  #22
KCFormula's Avatar
I posted this a while ago when I had the money to do some little things. I have now decided to do everything at once. I am still toying with ideas right now.
Old Feb 27, 2003 | 02:05 AM
  #23
NiteRider's Avatar
Were also going to retard the cam 2 degrees, good bye driveability.
Old Feb 27, 2003 | 09:50 AM
  #24
jonaddis84's Avatar
How do you do that on an LT1 when everything only goes in one way? Or do you not line up the two dots?
Old Feb 27, 2003 | 11:28 AM
  #25
NiteRider's Avatar
The cloyes timing chain let's you retard or advance by 2 increments, and yes it had to do with lineing up or de-lining up the teeth.
Old Feb 27, 2003 | 08:49 PM
  #26
jonaddis84's Avatar
Gotchya, even though I have no interest to do so, or even think it would help, is it possible to do that with the stock setup?
Looks like the guy that started this thread left, havent heard from him, hope all these posts helped some.
Old Feb 27, 2003 | 08:54 PM
  #27
Momar's Avatar
I believe you would have to have the aftermarket timing chain to advance or retard the stock setup. I also doubt that you will get much gain on that cam by retarding it. Think about it. If you are going to shift the RPM that you make power up and loose driveablility, I think you would be better off just getting a cam with slightly more duration. Then you should at least gain power with the loss in drivability instead of just shifting the rpms that it occurs at. I dont recall seeing what heads you will be using, but I hope it is not the stock ones.
Ben
Old Feb 27, 2003 | 09:17 PM
  #28
Beast96Z's Avatar
I was actually the first person on the board to run this cam. Some people say that it is to big, but in my opinion, it really dosen't act like a large cam. The powerband with a 112 LSA is very good in the lower RPM range, and would not reccomend the 114 LSA unless you are spraying or going blown. The whole design behind the XE grind is to provide better lower RPM power. You can get cams on whatever LSA you want, but comp actually on makes 2 XE lobes. One is much more extreme than the other, and requires better valvetrain equipment. The more extreme lobes are more or less custom order.
Old Feb 27, 2003 | 09:29 PM
  #29
Momar's Avatar
So which lobe are you running. Does the special lobe provide any benifit?
Ben
Old Feb 28, 2003 | 05:22 PM
  #30
Beast96Z's Avatar
I run the standard 3300 series XE lobe. The same one listed on everyones website now days. The 3100 series XE lobes are a little more Xtreme over the nose, which is a little harder on valvetrain, but kinda mimicks a solid roller. So power will be better, but you have to watch the high lift. Most will have to run 1.5 rockers as not to have piston/valve clearence problems. Check out the diffrences here. Each line is a single lobe, and you can have any two lobes put together to make up your own "custom" cam. http://www.compcams.com/catalog/230.html
