DynaSpark Vent tube routing
Old May 10, 2010 | 07:34 PM
94FormulaLT1's Avatar
I am cross posting this from the Ignition section since it actually fits in both.
I just upgraded to the DynaSpark since my Opti crapped out a couple weeks ago. It looks great, but wish they would of sent me some paper work with the thing. That being said, how do you route the vent/vac lines??
I am sure I could search around and figure it all out, but trying to get the car back together quick so I can get it outta the shop.
Old May 10, 2010 | 07:49 PM
RamAir95TA's Avatar
On a stock vented setup, the hoses travel from the driver side of the intake manifold, down past the coil to the optispark. Pretty much a straight shot.
Old May 10, 2010 | 08:10 PM
Where am I suppose to tap into the vac lines at?
Old May 10, 2010 | 08:47 PM
RamAir95TA's Avatar
On your 94 manifold on the driver side, there is a plug. You'll need the fitting for the intake manifold (or use the EGR nipple if you have it deleted) for the source of the vacuum. The other line goes from the optispark to the intake elbow (or anywhere after the MAF).
Old May 11, 2010 | 05:23 AM
I don't have a plugged hole on the drivers side of my 94. I just put a "tee" in the line for the EGR vacuum:
http://www.injuneer.com/images/photo.../dOptivac1.jpg
Old May 11, 2010 | 12:00 PM
sbs's Avatar
sbs
http://www.dynaspark.net/support/Dynaspark_GEN_I.pdf
found through this fancy new thing called Google:
http://tinyurl.com/2ehys2g
Old May 11, 2010 | 04:33 PM
Thanks. Got everything I needed.
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
Jul 10, 2015 02:23 PM
