duration question
Old May 7, 2008 | 03:44 PM
texas97z's Avatar
duration question
This may be a dumb question but how is duration calculated? I searched on this and did not find an answer to my question.
Just gonna make up some numbers for example.
Cam with 1.5 rocker is 230/230 duration and .500/.500 lift.
Cam with 1.6 rocker is ???/??? duration and .533/.533 lift.
I am assuming because the lift is changing that the duration is as well,true?
Old May 7, 2008 | 07:42 PM
brokegenetic's Avatar
Rocker only changes the lift, I believe the duration is determined by the cam lobe design.
Old May 7, 2008 | 08:50 PM
96capricemgr's Avatar
It will have a minscule impact on duration, not enough to bother discussing.
Old May 7, 2008 | 09:58 PM
carguy2112's Avatar
Why? Wouldn't the lifter still land on the base circle at the same time?
Old May 7, 2008 | 10:02 PM
YodiBrodi's Avatar
rockers wouldn't change duration at all, only lift and ramp rate. since the rocker has to open the valve further in the same amount of time (duration) it actually opens the valve faster. no impact on duration. no impact on duration. i sound like my dad.
Old May 8, 2008 | 05:17 AM
So you guys are arguing that a higher ratio rocker won't cause the valve to hit .050 lifts sooner or delay the point when it comes back down to that point??
The difference is miniscule not worth arguing but it does impact duration at the valve.
Old May 8, 2008 | 08:00 AM
texas97z's Avatar
Ok, so either way not worth discussing. Thanks for answering my question
Old May 8, 2008 | 08:58 AM
carguy2112's Avatar
I'll give you that one. If you measure at .050, it would make a tiny difference. If you measure at zero lash though (which is what the valve actually does), it would be the same.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
Cam's maro
Jan 30, 2015 09:21 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
