Duel Setup Help!
Old Dec 23, 2005 | 12:03 AM
MENEGRANDE's Avatar
Duel Setup Help!
My Y-pipe is craked and the hooker lt are rusted pretty bad, I want to get a whole new system. I would like to get a x setup with no cats, lt, and dump it in the middle. can it be done? if so what do i need to buy. its for the car in the sig
thanks
Old Dec 23, 2005 | 01:46 AM
Evil Eric's Avatar
Re: Duel Setup Help!
Are you going to buy a new set of headers? Rusted headers are a fact of life, even if you get coated ones it eventually wears off. i wouldnt buy new ones unless they are heavily damaged by rust. For your setup I'd reccommend going with a universal x-pipe setup like jegs or summit sells. you can cut the pipes to length to dump it where ever you want. What mufflers are you planning on using?
Old Dec 23, 2005 | 02:32 AM
Cmr0z28's Avatar
Ive had my LTs for 2 years and the Jet Hot coating is fine....no rust.
Old Dec 23, 2005 | 10:09 AM
MENEGRANDE's Avatar
headers are 3 years old but heavily rusted. I might aswell saved them and just do the x setup. now with midlength headers is that x setup still doable?
Old Dec 23, 2005 | 03:58 PM
WS Sick's Avatar
Have the headers coated, it will cost a little less than new headers...lol
But buy the universal X kit that's sold in Jegs or Summit, 2 18 inch bullets mufflers (by Dynomax) , 2 2 1/2 inch turn downs, and 2 header flange reducers (down to 2 1/2 inch). The set -up we put on a freinds car was really pretty straightforward. We put it all in place bolted it all up and then tack welded it all, removed it and welded all the seams. We used common exhaust hangers at the back. On a mildly cammed LT1 it sounds like a dragster.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
