difference in f-body, corvette and impala heads
Old Dec 18, 2005 | 08:51 PM
respectirocz's Avatar
other than impala lt1's having cast iron heads
and f-bodys and vettes having aluminum heads
what other differences are there
the reason i ask is because an engine re-ring kit (that includes main bearings rod bearings, piston rings, full gaskets and seals) has different part numbers for a 95 roadmaster, or a 95 camaro or a 95 vette
i think they all have the same basic bottom end
so the only thing i can think of is maybe the valve stem seals are different or something
Old Dec 19, 2005 | 11:29 AM
96flame's Avatar
Re: difference in f-body, corvette and impala heads
headgaskets are definately different between cast and aluminum, vettes got 4 bolt mains
Old Dec 19, 2005 | 02:44 PM
ok, are the head gaskets different between the camaro and the vette?
i dont think the vette having 4 bolt mains should play a role in the re-ring kit, but if i'm wrong correct me
any idea why there are three different gasket sets for these engines?
Old Dec 19, 2005 | 03:46 PM
flatlander757's Avatar
To charge the Corvette owners more
Old Dec 19, 2005 | 06:46 PM
96capricemgr's Avatar
The b-body kit would have a thinner head gasket the f-body and Vette head gaskets should be the same. Do the kits contain any bolts that should not be reused from the original engine? If so there might be your answer as to how 4 bolt mains could play a part, also doesn't the Vette use a different oilpan and if so could it be a different gasket. I know there are oil cooler differences and a lack of one on some cars those gaskets would vary some.
Old Dec 19, 2005 | 08:36 PM
its funny that u say to charge vette owners more because here are the prices
from HI-TECH
95 roadmaster
ch350my33 $439.99
95 camaro
ch350my29 $439.99
95 corvette
ch350my28 $404.99
these kits include all gaskets all seals,piston rings, no bolts, rod and main bearings
i suppose a different oil cooler would warrant a different gasket, but thats not enough for a $35 difference
Old Dec 21, 2005 | 12:18 AM
this forum is amazingly active i can hardly keep up
in a little more than a day this forum has moved to page 3
anyway
any idea what the differences could be?
Old Dec 21, 2005 | 10:02 PM
so what is to stop me from using the vette kit?
Old Dec 21, 2005 | 10:47 PM
Cerwin Vega Fan's Avatar
Nothing I suppose, maybe a few gaskets might not line up though.
Old Dec 22, 2005 | 06:30 PM
Lonnie Pavtis's Avatar
The Corvette has different exhaust manifold gaskets. The f-body uses the outer holes to bolt the manifolds on the extreme ends of the heads, whereas the Vette uses the inner ones (like most standard headers have)
Hope this helps
Old Dec 23, 2005 | 12:50 AM
Hope this helps
that makes a hell of alot more sense as to why they are different part numbers, thank you
if anyone could offer a theory as to pricing, i'd be glad to hear it
Old Dec 23, 2005 | 03:35 PM
FYI, the Vette gaskets will not work with the Camaro manifolds.
If my memory is correct, a Trickflow gasket set is approx $300.
On the last Vette I built, I bought the gaskets separately.
If you are having someone do your heads, they will probably include the valve seals in the valve job.
For headers you will need different exhaust gaskets anyway.
If so, you can buy a timing cover set, rear main seal & oil pan gasket set, intake set & a set of FelPro 1074's (for more compression than stock) head gaskets for about $175.
The other misc. missing parts such as injector o-rings in a complete kit may not be required anyway.
Not sure the brand of parts you get in your kit, but many are often generic parts in the economy kits. You may be better off buying brand names separately for the same or less money.
Good rings are approx $100
Good rod/main Bearings are approx $100
Old Dec 23, 2005 | 05:42 PM
Dave89IROC's Avatar
might be using old school SBC manifold gaskets..........
HectorM52
Jul 30, 2017 11:46 AM
pimpss96
Feb 12, 2015 01:28 PM
Moshbmx1
Jan 20, 2015 03:27 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
