Dual Cat Exhaust swap
Old Feb 14, 2008 | 10:32 PM
1993Z28LT16SPD's Avatar
Anyone have a 93-94 with the single cat and go to a dual setup from the later 95-97's? I wanted to see what would be involved, right now I've got a 3" single pipe to a 2 chamber flowmaster with 3" outlets the I put in in the late 90's. It's deafending/overwhelming at times, thinking of upgrading the whole system with headers, the dual cats and possibly a stailness cat back setup. Any thoughts on the dual cat swap and where to get them, other parts needed, etc.?
Old Feb 14, 2008 | 10:58 PM
GreasyB's Avatar
Why wouldnt you just go with aftermarket exhaust? Also this is better suited for the exhaust section of the forum.
Old Feb 14, 2008 | 11:41 PM
speed_demon24's Avatar
You should be able to have the catback modified to bolt up to your y-pipe. I'm going to add cat's to my true dual setup since I'm sick of smelling like gas whenever I drive my car.
Old Feb 15, 2008 | 07:47 AM
2000GTP's Avatar
It will require some modification to the i-pipe portion of the catback and you would have to have the rear 02 sensors removed and the bungs welded up. Frankly, it is alot of work for no gains. You would be better off just putting in a high flow cat in place of what you have now.
Old Feb 15, 2008 | 08:00 AM
reimer96z's Avatar
just get a catted y pipe with the headers and the cat back will bolt up to that
Old Feb 15, 2008 | 11:00 AM
I never understoody why people would only put 1 cat on a "high performance car" since it would be a huge flow restriction...
Old Feb 15, 2008 | 01:12 PM
truedualws6's Avatar
If you want to do it cheap all you need is to find a used setup from someone
along with the drivers side exhaust manifold. It should just bolt up and other
than extending/moving the location of the O2 sensor wiring I think it would
be fairly simple.
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
MadMav
Feb 6, 2015 11:02 PM
spearous
Jan 12, 2015 11:03 AM
Jan 5, 2015 07:14 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
