DTC codes 16 and 21. Where to look?
Old Aug 12, 2007 | 10:12 AM
kgkern01's Avatar
Since putting new heads and rockers on my car I have had an SES light, at first intermittent, then always on. It has had a high idle since putting back together along with cutting out at high rpm like hitting the limiter early. Otherwise has driven great. Also when car is off, the door locks and power windows have been a little weak, as if battery is almost out. Yesterday it died on me suddenly 3 times on my way home as if I turned it off with the key, went from running great to instantly off. Now won't start at all.
Here's my questions:
1. Do I need a new TPS due to code 21 and the high idle?
2. Is it a wiring issue, and if so, exactly what to check.
3. Where are all the grounds located, so I can check those.
4. Bad battery?
5. Chances of bad opti? Only been on the car about a year.
6. Other opinion's or advice?
Old Aug 12, 2007 | 11:00 AM
From Shoebox's code list:
DTC 16 = Distributor ignition system (low resolution pulse)
That codes sets when the PCM can not find the low res pulse from the Opti. Without that pulse pattern, the PCM can not sequence the injectors and spark correctly, so it shuts down the fuel system. That could be the "cut out" experience you had. Clear the codes by pulling the "PCM BAT" fuse for 30 seconds and see if it just happens to come back when the engine "cuts out". It isn't unusual to find that code "stored", and if the engine is running its a stored code, not an active code. First thing I'd check if you can correlate the engine cutting out to DTC 16 would be the Opti harness connectors.
DTC 21 = Throttle Position (TP) sensor circuit (signal voltage high)
That code sets when the TPS voltage exceeds 4.9V. You need to check the TPS sensor signal voltage. Measure between the gray wire and the black wire to verify the PCM is supplying the correct +5V reference signal. Then measure between the blue and black wires to verify the closed throttle voltage - should be in the range of 0.20 - 0.90V, with many people preferring something in the 0.50-0.67V range. If you have the correct closed throttle voltage, slowly rotate the throttle blades open, watching for a smooth voltage increase - no spikes or dropouts - all the way to WOT. At that point, the voltage should be roughly 4V higher than the closed throttle voltage. At no time should the voltage on the blue signal wire exceed 4.9V. If is appears to meet the specs, try jiggling the harness or tapping the sensor as you rotate the blades, to see if there is an intermittent problem.
If the TPS voltage is above 1.0 at closed throttle, it will result in a higher than normal idle, since the PCM assumes you still have your foot on the throttle and want it to be open.
Old Aug 12, 2007 | 02:27 PM
kgkern01's Avatar
I unplugged the positive cable from the battery for about 5 min, then tried it, still wouldn't start.
Code 21 test:
For the TPS, with the key in ON, I measured the gray to black voltage as 5.08 and the black to blue as 4.93 with throttle closed and held open partially was at 5.06. Is the 4.93v too high for just an idle of 1200-1500 rpm, or is that still limited by the actual throttle opening still? So I would assume with these readings that it means I need a new TPS sensor, correct?
Code 16:
As for as the not starting, would a bad connection at the opti cause that, and if so, how exactly would I go about testing that vs the opti itself?
Is it possible for a bad coil or ICM to cause this too, or should I go ahead and rule that out?
Old Aug 13, 2007 | 10:08 AM
Code 21 test:
If you have a reading of 4.93V at idle, its wayyyyyyyy too high. Needs to be in the range of 0.20-0.90V, as I explained in the first response.
Code 16:
Yes............... a faulty harness connector can interupt the low res pulse signal and prevent the engine from running. You have to look at the harness connectors and see if they are corroded or the pins are damaged. There are two connectors, one at the Opti and the gray "test" connector on the bracket on the passenger side of the intake manifold. If the harness is OK, you have to look at the system to see if the PCM is receiving the signal from the Opti. Shoebox tells you how on his website.:
http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Aug 20, 2007 | 10:20 PM
kgkern01's Avatar
Replaced the TPS, voltage is now good at .73V at idle.
Regarding the opti, checked the harness, and the plug is covered in blue corrosion. Is there a way that I can clean this off as well as the connections down in the opti? I really don't want to pull off the opti if I can somehow clean the connectors while its on the car.
Old Aug 20, 2007 | 10:48 PM
Electronics spray cleaner and any other mechanical method that you can safely use to get down in the opti connector. Don't snap the pins off.
Old Sep 22, 2007 | 01:42 PM
kgkern01's Avatar
Tested the opti connector at the manifold to PCM connector, using a digital meter set to DC put negative to ground and probed each wire with the positive and got:
D - .05v
C - 11.89v
B - 5.11v
A - 5.11v
Plugging the opti harness back in at the manifold and measuring at the opti end of the harness I got the same results. Are these results good or bad?
DirtyDaveW
Dec 1, 2016 05:37 PM
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
dreamer1q
Aug 20, 2002 11:19 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
