DTC code Question
Old Dec 13, 2003 | 12:05 PM
MonoxideChild's Avatar
DTC code Question
ok, I have a scanmaster. my MAF connector got snipped. I replaced it. But, it still reads a 48 DTC code? but, the MAf is reading normally? any reason why it's still giving me a 48 DTC if it's reading correctly?
Thanks!
Old Dec 13, 2003 | 12:13 PM
Have you pulled the PCM BATT fuse for at least 10 seconds to clear the stored code?
Old Dec 13, 2003 | 01:27 PM
hmm I figured after a few cycles it would dissappear.
I will do that.
Old Dec 13, 2003 | 01:40 PM
ok. pulled same error codes came up.
Old Dec 13, 2003 | 06:19 PM
HBHRacing's Avatar
how did you replace the connector. you might need to solder(sp) them due to teh fact that using butt connectors on the wire can change the resistence value to the computer
Old Dec 13, 2003 | 08:10 PM
used the supplied buttend connectors. but I'll need to dust off the old gun then. just to make sure.
Old Dec 13, 2003 | 08:50 PM
LeathernecK's Avatar
Did you clear the code with the Scanmaster? Hell, I don't know if they are capable..... If not, go to Auto Zone or Advance Auto and have them clear the code and see what happens.
Old Dec 13, 2003 | 10:34 PM
well, I lost my instructions that came with the scanmaster, so I am un sure how to clear the codes. :/
Old Dec 13, 2003 | 11:09 PM
The you have a couple options:
1. Remove fuses as stated above.
Most of the time this will work. However you need to be sure that the code is gone. Just because the light goes away doesn't mean that the code is gone. Your PCM will store codes.
2. Go to one of the above parts stores.. They have a diagnostic scanner that can view and reset codes. It is free and you will be sure that the code is deleted enabling further trouble shooting.
Good luck
Nick
Old Dec 14, 2003 | 12:10 AM
Since he has a ScanMaster, he will know if the code is cleared. When you pulled the PCM BAT fuse, was the ignition switch in the "off" position.... it should be.
What kind of MAF readings are you seeing? Sounds like an intermittent wiring problem.
Old Dec 14, 2003 | 09:37 AM
on the maf between 02-up to around 15-19 normal driving.
rpms up to around 4500
Old Dec 14, 2003 | 11:12 AM
The ScanMaster indicates "grams/second". What do you see at idle? 6 to 10gps would be typical. What do you see at peak power/WOT? 220-250gps might be normal.
Old Dec 15, 2003 | 11:35 AM
cold start is 6-7
after warm up it sits to around 4-5
I didn't watch it at WOT.
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
David Dorris
Jan 17, 2015 08:10 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
