DTC Code P1371
Old Jul 25, 2007 | 04:38 PM
eagleknight97's Avatar
DTC Code P1371
Distributor Ignition (DI) low resolution circuit
What does that mean?
Old Jul 25, 2007 | 04:42 PM
It means the computer is losing the low resolution signal from the opti. Could either be the opti or the harness to it that is causing a problem.
Old Jul 25, 2007 | 05:33 PM
If the engine is still running, its a "stored" code. Clear it (pull "PCM BAT" fuse for 30 seconds) and see how fast it comes back. If the engine isn't running, its "active" and you need to follow up on what Rob said.
Old Jul 25, 2007 | 05:36 PM
Engine is running. I installed Headers and new plugs and wires about 2 months ago. My front O2 sensors are bad and I dont have rear O2's. Other than that engine seems to run fine, nothing out of the ordinary.
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
timmy39120
May 8, 2015 11:41 AM
dreamer1q
Aug 20, 2002 11:19 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
