DTC Code 36: High Res Fail
Old Oct 10, 2009 | 03:42 PM
My Red 93Z-28's Avatar
What causes this?
Old Oct 10, 2009 | 03:57 PM
The high resolution pulse signal from the optical cam position sensor in the Opti is not (consistantly) reaching the PCM. Could be the sensor, could be the wiring, in particular the connectors on the ends of the short Opti harness.
Old Oct 10, 2009 | 04:39 PM
I was afraid thats what it was. Thanks Fred, I'll look into it
Old Oct 11, 2009 | 10:17 AM
Clear the code and see how fast it comes back.
Old Oct 12, 2009 | 06:54 AM
How can I clear it? Will just disconnecting the battery clear it?
Old Oct 13, 2009 | 05:15 AM
Don't pull the battery cable... you'll have to reset the security in the radio. Pull the "PCM BAT" fuse for 30 seconds, with the key "off". I think 93 and 94 the PCM BAT fuse is in the panel at the end of the dash.
Old Oct 14, 2009 | 07:26 AM
moehorsepower's Avatar
Originally Posted by My Red 93Z-28
What causes this?
that my friend is your Opti saying.....So Long bud....
Old Oct 14, 2009 | 07:33 AM
And it's only been in there for ~10,000 miles, I think it was put in about 4 or 5 years ago maybe.
Now the car won't start. I'm guessing that would be due to this problem. I also think my fuel pump is starting to go out, when I turn the key on (but not all the way over to start) I can hear it, but it runs longer than usual. The car ran fine Saturday, but when I went to start it again last night it wouldn't fire.
Also, Fred, I'm not sure what you mean by resetting the security in the radio...I've never had to do this before. I have an aftermarket head unit if that makes a difference
Old Oct 14, 2009 | 09:02 AM
I had a brand new GM Delco Opti that I picked up from my local Chevy dealer, and the car did not start. Took it apart, and the internals were pressed in 180 out..
Old Oct 14, 2009 | 05:38 PM
"security" only applies to the stock audio systems. Aftermarket is a different story.
Old Oct 14, 2009 | 07:06 PM
grumpygreaseape's Avatar
fuel, air spark-have you checked for spark at the coil?
Old Oct 14, 2009 | 07:16 PM
I was going to post asking the best ways to check for things like this. I want to check everything I can before I spend $400 on another opti
Old Oct 15, 2009 | 05:01 AM
Guest47904's Avatar
Guest
A 36 code won't stop spark or anything else. If you don't have spark at the coil, It's not from that.
Old May 27, 2010 | 10:03 AM
I know it's been awhile, but I need to get back on this. I checked a few things out a couple weeks ago. Fuel Pressure was good, but no spark at the distributor or coil. But a couple days before that it started right up???
Fred, I still need to check on the connection to the opti via the short harness. I've been traveling for work, but with the holiday weekend, I should have some time to work on it.
Thanks.
Old May 27, 2010 | 02:55 PM
Check for codes again... you may have DTC 16 by now, and that would prevent it from starting.
