DTC code
Old May 9, 2004 | 05:04 PM
GMH94Z28's Avatar
Question DTC code
Does anyony know what this means MALF 37: Brake switch stuck on. What does this do? Thanks
Old May 9, 2004 | 07:31 PM
n2ceptor's Avatar
TCC -- Transmission Converter Clutch, check your neutral start switch In the Haynes manual chapter 6- section 12.....
Old May 9, 2004 | 07:43 PM
Lyle A's Avatar
It has to do with the brake switch (at the pedal) being on (open) for specific amounts of time under specific vehicle speed conditions. If you ride your brake you will get the code. IF there is a problem with the switch or wires you will get the code. The switch is normally closed. When you push the pedal, it opens the circuit. If the circuit is open for specific conditions then DTC 37 will be set.
Old May 9, 2004 | 07:52 PM
Lyle A's Avatar
One more thing, it does affect the TCC/Shift interrupt. There are two other contacts on that switch that are normally open for the brake lights.
Old May 9, 2004 | 08:26 PM
GMH94Z28's Avatar
Lyle A
Do you know where the switch is located? Thanks
Old May 9, 2004 | 10:20 PM
Lyle A's Avatar
Mounted at the lower hole of the brake pedal bracket. Auto trans has 2 connectors, manual has one, same switch for both. The wire from it is lt. blue/black stripe. It is fed from fuse 9 in the IP panel and that wire is pink.
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
timmy39120
May 8, 2015 11:41 AM
dreamer1q
Aug 20, 2002 11:19 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
