Dtc 441
Old Feb 24, 2009 | 10:05 AM
socal96Z28's Avatar
Dtc 441
I just finished doing the intake manifold seal replacement and now I am getting a DTC 441 code (EVAP) I have checked all the vacuum lines and electrical connections and they are in good condition. Before I did the work I had never seen this problem, any idea what the most likely culprit is?
Old Feb 24, 2009 | 01:47 PM
socal96Z28's Avatar
Ok few more things I have checked now:
1) No apparent charcoal in the lines.
2) I disconnected the vacuum switch and the two electrical prongs(connector) give a closed condition (0 resistance) when I apply a little suction using a rubber hose and plugging the other side, it goes into closed condition (infinite resistance) So from what I am reading that appears to be working fine.
3) I applied 12 volts to the solenoid and it went from normally closed which I checked with a little rubber hose and gently sucking on it to open condition so I guess that is working fine.
When I suck on the hose going to the gas tank I appear to get no resistance, is that how it's supposed to be?
Now that I have checked to solenoid and valve separately what is the best way to check to see if they are working with the car running?
Old Feb 24, 2009 | 02:26 PM
moparman's Avatar
According to my OBDII tech book, the 441 can be caused by:
Vacuum leak
Cracked vacuum line/plastic connector
Vacuum switch
Plugged hose from solenoid to cannister or throttle body
It also implies the vacuum switch is usually the #1 suspect.
Old Feb 24, 2009 | 03:00 PM
socal96Z28's Avatar
Thanks moparman!
Well I found the problem! the line from the solenoid to the TB was plugged and even though the solenoid came on it never saw any vacuum. Now I am out to test drive it
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
