Dtc 38
Old Jan 9, 2006 | 12:39 PM
mickeyiz28's Avatar
Dtc 38
Car is throwing the ses light and that is the code its giving off, i looked it up and its got something to do with the brakes, anyone know what i could replace or fix to get rid of the light?
Old Jan 9, 2006 | 04:37 PM
Guest47904's Avatar
Guest
Re: Dtc 38
A DTC38 in a 94 & 95 is from the brake pedal switch not opening up to stop the battery voltage from going to the PCM when the pedal is depressed. But I was certain the 93 didn't use that code. In the 94 & 95's it does NOT set the SES light though. Are you sure you have a 38 and you don't have some sort of other code?
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
