fan switch ?
Old Jan 9, 2006 | 01:38 PM
deputydough's Avatar
fan switch ?
did a search, but did not answer my question. auto zone has a fan switch that is for an aftermarket fan setup. has anyone ever used it with the stock fans? it is only 15 bucks. will it work? thanks guys
Old Jan 9, 2006 | 05:11 PM
Guest47904's Avatar
Guest
Re: fan switch ?
Must be one hell of a switch for that price. Why don't you just tap into the fan relay already there so the switch will close the relay? Then it doesn't matter what switch you use and you don't need another relay. Best part of that is the switch you put it will only need to switch ground to command the relay on and you don't even go near voltage or fuses. Cool huh.
Jeff'SS
Jun 1, 2015 06:21 AM
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Sep 13, 2002 03:35 PM
troywg
Sep 12, 2002 07:28 PM
