DTC 18 what is it?
Old Jan 12, 2006 | 05:37 PM
Mikes 1994 z28's Avatar
DTC 18 what is it?
Just got my car back from the dealership to fix a misfire problem on my car. Now it is showing DTC 18 on my scanmaster. What could it be?
Old Jan 12, 2006 | 06:07 PM
Re: DTC 18 what is it?
A fault on the fuel injector circuits. One of your injectors has an open circuit, a shorted circuit, or just enough current leakage to tell the PCM that it isn't working correctly. The PCM can't tell you which injector it is. You have to figure that out yourself.
Maybe they forgot to plug one of the injectors back in - does the engine feel like its missing on one cylinder.
Old Jan 12, 2006 | 06:09 PM
I8ASaleen's Avatar
Is that a DTC 118?
Old Jan 12, 2006 | 06:16 PM
He apparently has a 94 LT1. That's OBD-I, and the trouble codes are in the form DTC xx, where xx is a 2-digit number. There are no OBD-I PCM codes with 3-digits.
On the OBD-II PCMs, the trouble codes are in the format Pxxxx, with four numeric characters.
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
