Dropping the motor without a lift...
Old Nov 6, 2008 | 09:27 AM
SnakeSkinner28's Avatar
I was wondering if anyone has done this? If so, any tips or methods you used to get the motor out without a lift would be appreciated...
Old Nov 6, 2008 | 10:53 AM
seawolf06's Avatar
I used an engine hoist to lift the body up and had the k-member on rollers. A buddy made a slick roll around out of roll cage tubing that would hold both the k-member and tranny together. Otherwise you can just use furniture rollers.
Make sure you block the rear tires and use good quality jack stands, not concrete blocks.
Old Nov 6, 2008 | 03:51 PM
thanks for the help...where did you lift from to raise the body up though?
Old Nov 6, 2008 | 03:53 PM
seawolf06's Avatar
The crossmember in front of the radiator.
Old Nov 6, 2008 | 10:37 PM
This topic has been discussed frequently on LT1 Based Engine Tech. There are posts with links to "how to" sites. Definitely not an "Advanced Tech" topic. Here's a link I've saved in the past.
http://www.michiganspeed.com/enginepull/index.html
Moving.....
And another:
http://www.cardomain.com/ride/348183/6
Old Nov 7, 2008 | 01:35 PM
hosspwr94's Avatar
info...
i have a couple of word documents with pictures if you want them very detailed (its not my work but was sent to me when I requested the same thing you did...
Send me your email and I'll shoot them to you.
Old Nov 7, 2008 | 02:36 PM
wrd1972's Avatar
Dont see how it can be done WITHOUT a cherrypicker or hoist to lift the front of the car up high enough to pull everything out from underneath.
Old Nov 7, 2008 | 08:34 PM
slowZ's Avatar
i used a coffin hoist attached to a rafter in my shop to lft it up enough to get everything out. make sure you raise the rearend up enough so you dont smash your tailpipes.
Old Nov 7, 2008 | 09:09 PM
Prorac1's Avatar
An industrial transmission jack works well also.
Old Nov 9, 2008 | 01:32 PM
evilawd4g63's Avatar
i used a basic floor with a 6x6 block on top of it, a couple tall truck jackstands, and left the front wheels on and rolled the whole thing out from under the car
Dmonty
Jun 2, 2015 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
Jan 5, 2015 07:14 PM
formula218
Dec 2, 2014 04:27 PM
