TFS 195 heads
Old Nov 5, 2008 | 12:27 PM
whyrun's Avatar
TFS 195 heads
Would a set of 195cc tfs assembled be worth 1000.00 new in box.. But would there be any advantage over stock heads since these are unported? just throwing this out there to see if anyone has any experence with the way these heads work..
Old Nov 5, 2008 | 05:42 PM
Kevin Blown 95 TA's Avatar
Sounds like a good price, but the chamber might be too large for your application, so make sure what you're getting. They probably outflow stock, but I don't have numbers on that.
Old Nov 5, 2008 | 05:49 PM
slomarao's Avatar
ive seen their stock flow numbers, Mid 250 on tha intake @ .600. Way better than stock, but the large chambers will drop your compression unless you get them milled.
Old Nov 6, 2008 | 02:53 AM
SuperbeaSSt's Avatar
Nothing wrong with them if you have the right piston combo. But I guess these guys know more about your specific app.
Old Nov 9, 2008 | 01:45 PM
evilawd4g63's Avatar
i have these heads on my car. unless you either change pistons or run some type of forced induction i HIGHLY recommend STOCK ported units. the only reason mine are still on there is because im gonna go turbo.
LeftoverChinese
Jan 14, 2024 03:03 PM
95chwagon
May 27, 2015 09:53 AM
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
