dropping motor help immediatly.
Old Jul 26, 2007 | 10:09 AM
06lingenfelter's Avatar
need help dropping my motor. i have all the stuff disconnected and the motor is just hanging in the engine bay on a cherry picker. my k member is loose and all i need to do is remove the bolts and its off. do i need to do something with my springs and suspension. please help and give me directions on the easiest way to drop that damn motor. oil pan and crank is already out. i spun a rod bearing.
Old Jul 26, 2007 | 10:17 AM
Sweetred95ta's Avatar
Maybe this will help.
http://ken.lowrance.com/Projects/Hea...ineRemoval.htm
Old Jul 26, 2007 | 10:44 AM
wrd1972's Avatar
There are two ways to do this:
1. Remove the tops of the coil-overs from the chassis, this requires removing the brake master cylinder to get that one bolt out for the driver side.
2. Remove the bottoms of the coil overs at the control arms and pop the upper ball-joint loose.
I prefer option 2.
Old Jul 27, 2007 | 08:54 PM
ok well i pulled my motor from the top instead of dropping it out the bottom. everyone said that it is impossible but i didnt think so and obviously its not. so if anybody has questions feel free to ask. **** dropping the k member and removing coil overs. i thought that was dumb but oh well i figured it out, so can you.
Old Jul 27, 2007 | 09:06 PM
12SCNDZ's Avatar
With the transmission unbolted, a "happy hooker" lift plate, and a long boom, 4 ton cherry picker, mine came out and went back in with absolutely no problems. I dare say it was actually pretty easy. The main key was turning the engine at about a 45* angle to get it to clear the core support. BTW, it also went back in with the intake, electric water pump, and balancer attatched.
Frank
CPT
Old Jul 27, 2007 | 09:53 PM
84 monte SS's Avatar
Ive gone in and out, through the top, motor and tranny connected, with the hood STILL BOLTED ON. (intake mani off though)
Old Jul 28, 2007 | 09:04 AM
12SCNDZ's Avatar
Yup. We never took the hood off mine, either.
Frank
CPT
Old Jul 28, 2007 | 10:54 AM
SS RRR's Avatar
I prefer option 2.
You mean the castle nut on the upper A-arm? But yes I agree.
Old Jul 28, 2007 | 12:51 PM
yeah i had my hood off but evereything else was still attached and yeah your right that 45* angle definatly helps. a little twisting and turing and tugging will get her done. It actually came out a whole lot easier than i thought it would. will it go back in just as easy? thats my question. thanks for the replies guys. keep it up.
Old Jul 28, 2007 | 01:40 PM
damastertechjj's Avatar
Can you guys post some pictures of the removal of the engine from the top.
Old Jul 28, 2007 | 03:15 PM
12SCNDZ's Avatar
Mine went back in extremely easy, also. I just had 2 buddies watch and guide it, while I lowered it in. I was working with a freshly painted engine bay, so I was even extra careful.
Frank
CPT
Old Jul 28, 2007 | 08:03 PM
wrd1972's Avatar
Yes
Old Jul 28, 2007 | 08:39 PM
95LT1conv's Avatar
I prefer option 2.
I didn't have to remove the master when I changed my front shocks
Old Jul 28, 2007 | 11:07 PM
Sean94Z's Avatar
I've done this both ways, I think it's easier from the bottom.. Of course, you do need to go get re-aligned when you are done.
Old Jul 28, 2007 | 11:57 PM
I don't know who said it couldn't be done out the top. A lot of people do it that way. I went out the bottom. Did it by myself. Left the wheels on and just rolled it out with a floor jack under the transmission. I thought it was pretty easy.
