Tune With Headers
Old Feb 6, 2008 | 03:01 PM
a4z28's Avatar
Tune With Headers
My question is if you do longtubes and eliminate the cats will the car run rich or lean. Cause i just did mine and my car seems to be smooking a little i think it is running rich. My gas mileage sucks now and i can smell gas from inside the car. I havent yet tuned it for the longtubes and cat delete but i have a regular pcm4less tune for my gears converter and coldair. If i get a tune for the headers will it actually make a big difference. Thanks
Old Feb 6, 2008 | 03:10 PM
2000GTP's Avatar
You don't need a tune for long tube headers. Now that the cat has been deleted, your exhaust is going to have a more obnoxious smell to it. But if your gas mileage has decresed and the gas smell is very overbearing, you might have issues going on elsewhere. I would make sure you don't have any exhaust leaks before the 02 sensors and that you may have not disturbed anything else during the install. How is the car running otherwise, any other symptoms? Do you have an SES light?
Old Feb 6, 2008 | 03:36 PM
a4z28's Avatar
Actually the car has a little shake to it like a miss but shows no ses light . My freind with a snapon scaner said that everything is good right tps reading o2 is reading right map is good but i think it might be a iac valve. I had this shake before the header install so i am leading to that. My freind also said that the smell i am getting could be a leaky injector.
Old Feb 6, 2008 | 03:37 PM
ss.slp.ls1's Avatar
If I'm not mistaken, IF you have an exhaust leak before the o2's, they will compensate by adding fuel, you could disconnect the o2's and run the car in open loop and see if it runs leaner. If it does than maybe you have an exhaust leak or you may have bad o2's.
Old Feb 6, 2008 | 06:51 PM
2000GTP's Avatar
I haven't worked with a Snap-On scanner in years so I cannot recall their functions, but are they capable of plotting cylinder misfires? If so, did you record any?
Old Feb 6, 2008 | 09:10 PM
slomarao's Avatar
i think theres something to gain with a tune after lt's. Ive read articles in gmhtp where they did this on cars and had small gains. (5-8hp)
HarleyZ28
Oct 5, 2015 06:23 AM
thenewkid
Apr 12, 2015 07:42 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
Cam's maro
Jan 30, 2015 09:21 PM
k1996z28
Jan 21, 2015 07:22 AM
