Dropped the engine tonight
Old Jul 24, 2005 | 08:40 AM
  #16
Dave89IROC's Avatar
Re: Dropped the engine tonight
Originally Posted by cehan
Did you take off the brake calipers? Seems like if you removed them from the rotors and hung them with some wire it would save from having to bleed the system when everything is back together. If you did take off the calipers, what do you use to cap the brake lines to keep all the fluid from running out of the system?
wont work, you have the brake line going across the crossmember under the engine
Old Jul 24, 2005 | 08:44 PM
  #17
cehan's Avatar
Oh yeah, I forgot about that. So, where is the best place to disconnect the brakes, at the ABS? The reason I'm asking is that I'm in the process of pulling my engine, all that's left is the short block and I did it one piece at a time, because it started out as just pulling the heads, and now I'm into overhauling the whole engine. But going back together, this sure looks like the best way to put it back in. One other question, I have a 2 ton hoist, adjustable to 1-1/2T, 1T, & 500 lbs. What do you think the front of the car weighs, minus the engine and K-member?
Old Jul 24, 2005 | 08:50 PM
  #18
Dave89IROC's Avatar
yes, just disconnect the 2 front lines, and gently flex them towards the engine..
and your hoist setting are not as you listed, they are 4000lbs(2T), 3000lbs(1 1/2T), 2000lb(1T), and 1000lbs(1/2T)
I think I would put it to the 2000lb(1T) location, but let me ask Quentin (he wrote that walkthrough)
Old Jul 25, 2005 | 02:08 AM
  #19
hvyss's Avatar
We have it down to an art. Using a happy hooker on my IMP and my buddie's 95Z we can have the motor out and on the ground in less than two hours. Pulling it from the the top. Not dropping the K member. The last install on the Z was motor and tranny together from the top. In and running in 31/2 hours. Practice makes perfect!!!
HVY SS
MattFick
Feb 15, 2015 10:16 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 5, 2015 07:14 PM
nballisru
Dec 14, 2014 05:01 PM
wytblur
Aug 5, 2002 02:03 PM
