Dropped the engine tonight
Old Jul 21, 2005 | 11:58 PM
Ripped's Avatar
It went well, but I was tired as h*ll. Started work @ 6:30 and went right into the car @ 4:30 when I got home. stopped at 9:45 whew
Unhooked most everything except for the belhousing, water pump and a few vaccum line
Just have to lift the engine off the K member and drop it at the engine shop, then we are on vacation for 2 weeks
Old Jul 22, 2005 | 12:08 AM
1racerdude's Avatar
Re: Dropped the engine tonight
Way to go.Keep up the good work.Ya got two weeks to rest up so ya can do it the other way.
Old Jul 22, 2005 | 12:14 AM
RedRyder518's Avatar
Are you taking it out from the top? I would of figured through the bottom is easier. Hmm...
Old Jul 22, 2005 | 08:54 AM
Ripped's Avatar
Yeah. Dropped out the bottom
rolled out the k-member on the front wheels, gotta undo the motor mounts and lift it off the K
Old Jul 22, 2005 | 09:01 AM
Victory Racing's Avatar
What plans do you have for your project?
Seems 383's with 12:1 SCR and a 150-200hp shot are the becoming the norm around here. What is your combo going to consist of?
Old Jul 22, 2005 | 09:22 AM
BLinindoll's Avatar
I heard it was easier to drop the k-member and engine and tranny all at the same time. That way you can put a jack under the tranny and roll the whole assembly away on the k-memeber and wheels. Am I wrong? Mabey I'm thinkin of an LS1.
Old Jul 22, 2005 | 09:42 AM
GetaZforgetGT's Avatar
That's exactly how I did mine.
Just don't forget to unhook the slave cylinder or you'll be buying a new one.
Ask me how I know.
Old Jul 22, 2005 | 11:01 AM
Ask me how I know.
How do you know?
Old Jul 22, 2005 | 11:54 PM
Ripped's Avatar
We dropped off the engine tonight, and we are off for two weeks vacation.
When we were there, he just had a pair of 572 cu marine engines and another pair of 800 hp supercharged bbc marine engines that were dropped off.
He asked us what we want to do
So we'll think about it. 1st we have to see what's wrong with the engine, and get a magnuflux on our assy etc etc.
I usually like a fairly bullet proof over built engine, designed around the cam, and hp.
Broke too many parts to be cheap where it counts, we'll know in two weeks where our baseline is
Old Jul 23, 2005 | 08:03 AM
new_z's Avatar
awesome post! i may need to pull mine when i get in the states. im doing a gm 847, and a little more should i pull it? anyone have pics of the steps? ive only pulled a 400 outta a 81 T/A and a daytona trubo FWD. both out the top, just heard of this bottom stuff a lil while ago! thanks guys.
michael.mastej@blab.centaf.af.mil
Old Jul 23, 2005 | 08:34 AM
Dave89IROC's Avatar
out the bottom
if you have a hoist its even easier
http://www.michiganspeed.com/enginepull/index.html
Old Jul 23, 2005 | 01:51 PM
new_z's Avatar
hey man that link is bad *** i never had it explained. i bet i could even figure it out now
youre the man
Old Jul 23, 2005 | 06:11 PM
mojorisin's Avatar
what do you mean if you had a hoist it would be easier? did you not use a hoist?
Old Jul 24, 2005 | 01:53 AM
Dave89IROC's Avatar
I mean a vehicle lift
did you read the link? he used a engine hoist to lift the car off the front subframe
Old Jul 24, 2005 | 07:14 AM
cehan's Avatar
Did you take off the brake calipers? Seems like if you removed them from the rotors and hung them with some wire it would save from having to bleed the system when everything is back together. If you did take off the calipers, what do you use to cap the brake lines to keep all the fluid from running out of the system?
