Drivers side head won't budge
Old Apr 22, 2006 | 11:29 AM
archangelus2's Avatar
I am taking my heads off to fix some bolt holes and I think I have removed everything. I planned on taking off the heads at the same time to avoid the crossover tube problem. I haven't taken the bolts off of the Passenger head or the rocker arms.
On the drivers side head I have taken the ignition coil off, IM, spark plugs, fuel rails, rockers arms, manifolds have been out, and I have double checked the 17 cylinder head bolts numerous times.
I am just trying to pry it up to see if it will come off and it isn't budging. I have tried screw drivers, wrenches in the ports, rubber hammers....Would to crossover tube in the back keep it from coming off, I think I am going to try to get the other to come upOn now and come back to the drivers side.
Any suggestions are greatly appreciated,
-Gabriel Terrel
Old Apr 22, 2006 | 12:06 PM
Fastblackcar's Avatar
Re: Drivers side head won't budge
There a 2 bolts that are "hiding" on the left and right side. You should have 16 bolts total, if I can remember.
Old Apr 22, 2006 | 04:42 PM
Welp, I finally got both of them off.
While the drivers side was still "stuck" I went ahead and got all the bolts off the passenger side head. I then put a flat head in between the passenger side head and the accessory bracket and it came loose real quick.
Then it was time for the drivers side head. I put a flathead screwdriver and tried to pry as much as possible in between some bracket or something right below the front of the head. After a couple whacks with the rubber hammer and mallet it started to show signs of giving. Then it was all downhill from there.
I just hope I can get all this back together next weekend.
karnykamaro
Feb 2, 2015 01:37 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
