Driven Water Pump Shaft
Old Feb 4, 2004 | 12:11 PM
  #16
93ZM6Tally's Avatar
Originally posted by Ken95Z28
Now you see it.
Now you don't
Pretty painless project, used a slender pry to removed it.
Hey! The front of your motor looks just like mine. I agree it was one of the few things that I've done on an LT1 that were actually easier than I thought.
Old Feb 4, 2004 | 01:05 PM
  #17
quicksilver97ta's Avatar
What did you guys use to plug the hole in the timing chain cover? A freeze plug?
Old Feb 4, 2004 | 01:12 PM
  #18
93ZM6Tally's Avatar
Haven't done it yet. But I've seen two different methods.
1. Short bolt with two washers and some sealant. Requires grinding down back of TC cover so that it is flush.
2. Freeze plug.
I'm going to try number two. If I cant find a plug of the proper diameter I'm then going to go with option 1.
Old Feb 4, 2004 | 03:20 PM
  #19
Mtrhds94Z's Avatar
Originally posted by 93ZM6Tally
I'm replacing the timing set with a tru-roller. One of the advantages of having an electric WP.
Safe to assume that you have done a cam and late/vented opti upgrade also, right?
Just a reminder..
Old Feb 4, 2004 | 03:24 PM
  #20
Zerosheaven's Avatar
can the hole just be left open without plugging it up or will that cause problems?? not the timing chain cover one the other one where the water pump drive was mounted
Old Feb 4, 2004 | 07:05 PM
  #21
97FormulaWS-6's Avatar
I left the one in the block open and have had no problems...
Old Feb 4, 2004 | 08:36 PM
  #22
93ZM6Tally's Avatar
Just a reminder..
Why? J/K. Yeah I've had a 95 style opti since I've had the car. As for the hole in the block. I'm going to plug it, but I see no real reason to other than I'm a little **** about my car. There are two oil galleys right next to it, at about the same height, so I don't see how having another hole would cause any problems.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
KYWes
Apr 15, 2015 07:28 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Zone
Jul 29, 2002 07:43 PM
