Drive shaft vibration????
Old Mar 27, 2003 | 05:59 PM
BottleFed94Z's Avatar
What exactly does the drive shaft vibration feel like? I know I have the original steel drive shaft in my 94 and it seems like I have a weird vibration around 80mph. I did replace the stock tranny mount with the energy sus mount. I know GM did some kind of recall for cars that did have the vibration and replaced it with the aluminum version. Can this still be done?
Thanks.
Old Mar 27, 2003 | 06:20 PM
ttt
Old Mar 27, 2003 | 06:26 PM
Rodrigues's Avatar
I dont know about a recall but I would just buy an aluminum driveshaft and have it balanced. You could just get your stock one re balanced but if its anything like mine its totally covered in rust, I bet ya I will be able to break it with my new mods
Old Mar 27, 2003 | 06:29 PM
Yeah, Im working on an aluminum shaft right now.
Old Mar 27, 2003 | 10:33 PM
GPZ1100's Avatar
To the original poster,
My '97 with the steel vibrashaft felt like the car was humming at speeds of 65-70 mph and above. It wasn't a constant humm, more like a cyclic humm... humm on, humm off (building up and decaying in between).
I finally got around to getting an aluminum shaft installed, now it just has a slight resonance around 65 mph, but goes away when speeds are over 70, which is fine, since I rarely drive 65
If you do lots of long high way trips, get it done, otherwise if most of your car use is in the city, don't bother (unless you're funded well )
Old Mar 28, 2003 | 10:49 AM
Thats exactly what my car does around 70mph and up. I feel it more the faster I go. I'm working on a driveshaft deal off of an LS1 car. I do like to take hwy trips in my car so I think I'll go ahead and buy it.
Old Mar 28, 2003 | 11:38 AM
GREGG 97Z's Avatar
It wasn't a recall just a TSB, technical service bulletin on the problem. They did not tell anyone to bring there car in for a new driveshaft or anything but if a customer was having vibration problems with the stock steel shaft the fix was for them to intall an LS1 aluminum. I'm pretty sure this only applied to cars that were still in their 3/36 or longer warranty. My stock vibeshaft ruined my rear at 20k miles one day when I was making a brief run just a little over 100 GM gave me a complete new rear, housing and all and an LS1 ds no charge
Old Mar 28, 2003 | 12:18 PM
93zder's Avatar
My car makes a on/of humming sound at highway speeds as well, but i don't feel any vibration though - could this be the same cause?
Old Mar 28, 2003 | 12:49 PM
Euclid's Avatar
Gregg,
How long ago was this? You think I could take in my 97 and have em do it for free?
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Cam's maro
Dec 28, 2014 09:30 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Victory Racing
Sep 1, 2002 06:05 PM
