draining engine coolent
Old Aug 13, 2005 | 01:34 PM
weinerschizel's Avatar
I was wondering if anybody new a good method to catch most ALL of the coolent without getting it dirty, while removing the water pump. I just redid my coolent system and now need to have the pump off again as I think the opti is going.
I have several containers to hold the coolent in, and want to reuse it. However, last time I removed the waterpump it was a bloody mess. How can I acomplish this and drain most everything into a container for reuse?
Thanks!
Old Aug 13, 2005 | 01:49 PM
Birdman7389's Avatar
Re: draining engine coolent
Place your container under the petcock on the radiator, thats about the only coolant you will be able to keep "clean"
Old Aug 13, 2005 | 02:50 PM
1FASASZ's Avatar
also drain the coolant out of the knock senser hole
Old Aug 13, 2005 | 03:40 PM
blunto's Avatar
Food for thought:
http://forums.corvetteforum.com/show...50&forum_id=48
Old Aug 13, 2005 | 03:49 PM
When you do the drain out of the radiator, make sure the cap is off, and also loosen your air bleed screws to get all you can out.
Old Aug 13, 2005 | 03:56 PM
chuckd4more's Avatar
there is a 'plug' in the same local as the knock sensor but on the opposite side of the engine. not sure if you will be able to get something under it and keep it clean but you could look at it and see.
Even if you drained the block down some, you wouldn't loose so much when you pull the WP.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Sandersen511
Jan 13, 2015 03:49 PM
pologreen97z
Dec 2, 2014 10:42 AM
