Drag wheel and tire ?
From: Albuquerque,NM--5,600 feet above you sea-level cats
I want to run a 28x10.50 slick. Will they rub? I'm guessing I need a 15x10 wheel. What back spacing do they need to be(7.5 maybe) I don't mind pounding out things here and there just not sure what will work and what wont.
Yes. But if you mean a 28x10.5-15W, you will have to do some serious pounding on the inner fenders.
15x10 wheel, 7.5" BS. I ran QTP 28x11.5-15's with no problems until trap speeds went over 125mph... then the tires were growing enough to start hitting the edges of the wheel opening. Just moved the axle back about 1/4" and let the tires "radius" the rubber bumper cover.
carguy0119
Apr 11, 2016 11:11 PM
