dowel pin question
Old Nov 30, 2006 | 01:29 PM
94_camm's Avatar
dowel pin question
Ok..well i think my dowel pin is to short.i went to go put cam sprocket on n the dowel pin doesnt even stick out!!can i replace it with a longer one?what tool do i use to measure the dowel pin? thanks 94z!
Old Nov 30, 2006 | 01:31 PM
Javier97Z28's Avatar
Moderator
Tool to measure? A set of digital calipers will get ya an exact #.
Should probably take it to a machine shop to replace the dowel.
Old Dec 10, 2006 | 06:00 PM
solarofthesix
Guest
Posts: n/a
i have the same problem but this is going onto a 95z...was ground down to fit a 94...how do they remove these pins?
Old Dec 10, 2006 | 06:09 PM
bingo's Avatar
Sometimes you can pull it out with visegrips. When I upgraded my opti to the vented style I could not get the dowel to move. I bought a new dowel at the dealer and had a machinist swap them. He said he had to use a dental drill to get it out.
Old Dec 10, 2006 | 08:03 PM
grammerman's Avatar
If the bore for the dowel pin goes through to the back side of the cam journal you can usually drive them out with a small punch. I bend the end of a 1/8" punch so it will clear the cam lobe then turn the cam up on end, insert the tool into the hole from the back side and drive the pin out with a hammer. Good idea to wrap the lobe up in several turns of tape to protect it. Punches are often brittle so a litte heat may be required to bend them.
Later, Michael
Old Dec 10, 2006 | 09:50 PM
solarofthesix
Guest
Posts: n/a
yea mine doesnt have a hole in the other end
Old Dec 11, 2006 | 09:46 AM
Colin91Z's Avatar
There is a tool that is used for removing dowels. Any machine shop that can turn a flywheel will have one...Dang I wish I had asked you what year your car was, I know someone who has this tool that I speak of. I could have removed it before I shipped the cam to you
btw...does anyone know exactly what length the dowel is suppose to be for a 95+? All this dowel pin talk makes me wanna go double check the one on my LE3 cam...
Old Dec 11, 2006 | 10:37 PM
solarofthesix
Guest
Posts: n/a
about 0.650" for 93-94......0.840" for 95+...........yea all projects ahve some BS thing going on....I ordered anntoher one form GM...should be here by Wed
Old Dec 12, 2006 | 06:15 AM
sssalah's Avatar
The dowel pin for vented opti motors is 0.610 - 0.620, not sure about the non vented but it should be a great dela shorter maybe 0.340".
For the original poster: the dowel on a 94 should not stick out from the cam sprocket it's just used to index the cam, the 3 5/16" bolts will retain the cam to the sprocket.
Old Dec 12, 2006 | 07:32 AM
.840" on a vented opti (95+) will destroy it in a short time. .650" is more like it.
I think you may have misinterpreted the information on my website.
Old Dec 12, 2006 | 07:32 PM
solarofthesix
Guest
Posts: n/a
ahh i realize that now, i tihknk the .840 or whatever was what compcams sent their cam in as....thats my fault...thanks for correcting me
sscott
Jan 17, 2015 04:30 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
Red97LT1
Aug 15, 2002 08:33 AM
