Dowel pin length from Cam Sprocket face
Old Mar 28, 2004 | 11:51 AM
ibanez6rg's Avatar
Anyone know this? I'm using Cloyes double roller, but that shouldn't matter.
Old Mar 28, 2004 | 01:33 PM
Alex94TAGT's Avatar
Well, first off, are you using a 1994-compatible Cloyes timing set? Or are you upgrading to the 95+ vented opti? If not, I hope you have something figured out with the '94 optispark's driveshaft -- otherwise you wont have an operating ignition system.
You can find the correct 1994 Cloyes timing set (p/n CLO 92-94) at the following link: http://www.moreperformanceinc.com/timgchn.htm --I dont believe it's a double-roller.
According to the following link, the dowel pins should be (.320") for a pre-95 vehicle, and (.685") on a post-95 vehicle, though I've seen this number vary depending on who you ask. Perhaps those are the full dowel pin lengths, and not the distance from the cam face. If you've done a cam swap, you should match the new cam's dowel to the length of the old cam's dowel -- unless upgrading optisparks. http://www.automotiverebuilder.com/ar/ar99928.htm
Old Mar 28, 2004 | 02:05 PM
ibanez6rg's Avatar
I'm running a 95+ vented opti setup. The dowel pin exceeds .620 from the cam face. For some reason I'm not getting spark and was just wondering how far the dowel pin should exceed beyond the face of the sprocket. Although I don't think that's my problem.
Old Mar 21, 2005 | 04:27 PM
slp223's Avatar
Re: Dowel pin length from Cam Sprocket face
drive dowel height (from cam face) .605 max
drive dowel height (with cam gear installed) .375 max
drive dowel O.D.: .250 max
oldschool
Feb 9, 2016 09:21 PM
meissen
Jun 1, 2015 07:59 AM
BigWil
Mar 29, 2015 12:24 PM
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
