dowel pin length
Old Mar 7, 2007 | 08:16 PM
1badasZ's Avatar
dowel pin length
i had given up on my car but i put too much money into it to just leave it alone. imma tear it back down and start from scratch i guess. i have a comp extreme 230/236 cam. can someone tell me the correct dowel pin length for a 95 camaro with vented opti. imma start there to make sure im not killing optis with the cam
Old Mar 7, 2007 | 09:00 PM
OBE1 95Z28's Avatar
From Shoebox's site:
GM specs indicate that the dowel should be .620" long (protrusion from the front face of the cam) for the vented optispark. Some people have said it is supposed to be .685". Mine was actually .650" and still was in no danger of bottoming out in the optispark drive (I'm thinking .685" might be the max it could be)
Old Mar 7, 2007 | 10:11 PM
itzkwik's Avatar
the difference is pretty big , i have a 96 formula , ordered a 96 billit cc306, had the motor built , well it must have been a 95 motor cause the opti wouldnt fit so I measured the dif. , taped everything off and got after it with a dremel cutoff wheel, 8500 mi later still works
13qtr
Oct 28, 2016 08:11 PM
Novo
Jun 14, 2016 02:58 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
