dowel pin
Old Jun 21, 2004 | 10:14 PM
Lt1dtpower's Avatar
dowel pin
How do I change my dowel pin without messing it up. My stock one measures .620 and the one on my comp cam is alot longer. What is the best thing to do. Thanks
Old Jun 21, 2004 | 10:17 PM
Spinner's Avatar
Just dremel it off and sand the tip smooth
Old Jun 21, 2004 | 10:21 PM
simple's Avatar
or grinding wheel or something along those lines, just keep an eye on length as to not take away too much
you only need to swap them if the new one is too short
Old Jun 21, 2004 | 10:25 PM
Lt1dtpower's Avatar
thanks guys. Hey spinner are you using Lloyds heads.
Old Jun 21, 2004 | 11:20 PM
Spinner's Avatar
whenever they show up.
Old Jun 22, 2004 | 08:46 AM
Lt1dtpower's Avatar
Has he had them long. I'm sending mine taday. He told me two and half weeks once he has them.
Old Jun 22, 2004 | 10:30 AM
Spinner's Avatar
about two and a half weeks
Old Jun 22, 2004 | 11:40 AM
Don 97 SS's Avatar
I did as Spinner suggests. I took a grinder and brought mine down to .615". I also put a slight (I did say slight) bevel edge at the tip on mine. The dowel's OD should not be more than .250".
Old Jun 22, 2004 | 01:56 PM
All_Z_Way's Avatar
I just measured with a tape measure the length it needed to be and then marked the pin and cut it off with a dremel tool.
Novo
Jun 14, 2016 02:58 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
