double roller timing chain
Old Jan 29, 2011 | 06:56 PM
manfire1987's Avatar
From what I have hear there is something that has to be done to make the double roller timing chain fit on my 96 lt1 camaro.. the whole build is finally gonna come all together after a year and I just want to make sure I got everything together before I start want a smooth process so if camaroz28 can help me out once again that would be great!! Thanks again everyone!!
Old Jan 29, 2011 | 08:02 PM
Re: double roller timing chain
This would getter better results in the "LT1 Based Engine Tech" forum, than in "Drivetrain". I'll move it there for you.
Old Jan 29, 2011 | 09:39 PM
RamAir95TA's Avatar
You need an electric water pump, delete the CKP, install an earlier OBDI-type crank hub (or shim the OBDII hub), and trim the rear of the timing cover. Ideally you'd want a 95 timing cover too...it has a vented opti but no provision for the CKP, but you can make the 96+ work.
Old Jan 30, 2011 | 02:06 AM
CkP I knew there was something didn't realize it was all that much
Old Jan 30, 2011 | 03:52 AM
So removing the ckp is not going to mess up the performance part of the car?? From my research the 96 with OBD 2 that is the only difference is that sensor.. switch to OBD 1 anyhow they can do the bypass that code correct??
Old Jan 30, 2011 | 04:20 AM
also another question when running this timing chain do I need to advanced timing or is it dead on thanks
Old Jan 30, 2011 | 09:38 AM
The CKP sensor was added in OBD-II to detect misfires. It serves no other purpose, and can be deleted without any affect on the way the engine runs. You will have to have the code for the CKP sensor programmed out to avoid staring at an SES light all the time.
There are numerous other differences in OBD-II, including a mulitude of diagnostics, the EVAP vacuum detector and after-cat O2 sensors.
Old Jan 30, 2011 | 02:43 PM
All smog **** is coming off of the car... The original plan was to convert it back to obd 1 anyways but I have heard diffent stories on that as well... Thanks for the help guys..
Old Jan 30, 2011 | 09:17 PM
RamAir95TA's Avatar
All timing is adjusted via the PCM. Just install the chain dot to dot and you're good to go!
Old Jan 31, 2011 | 02:53 AM
Great thanks...
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
