done some searching, have some ?'s
Old Feb 24, 2009 | 11:29 PM
PowerAddict's Avatar
I can't find a few things:
I'm looking for builds with stock ported heads, ported intake, a cam, and exhaust, namely hp numbers.
how big of a lift can you go with stock pistons?
Thanks!
Old Feb 25, 2009 | 10:20 AM
silentsprintero's Avatar
Originally Posted by Stl94LT1
I'm running a 224/230 605/622 (1.6) camshaft with my stock short block.
Just do a search for "max lift stock block" tons of threads come up.
Old Feb 25, 2009 | 12:16 PM
95Blackhawk's Avatar
Thanks!
I did 321 RWHP /330 RWTQ with CAI, exhaust, headers, ported heads, ported intake and stock cam. I was peaking at around 5900.
Old Feb 25, 2009 | 01:18 PM
96m6lt1's Avatar
Lloyd Elliot http://www.elliottsportworks.com/lt1.html
AI http://www.advancedinduction.com/
Old Feb 25, 2009 | 03:07 PM
wow, thats amazing! Did you port the heads and intake yourself? Is that stock valve size?
Old Feb 26, 2009 | 10:34 PM
Had the heads professionally done. It was basically a cleanup and a little bit more. Nothing major. Valve sizes were a step up from stock.
Old Feb 26, 2009 | 11:06 PM
rskrause's Avatar
Moderator
Duration has more to do with piston to valve clearance than max lift. Any cam a reasonable person would use with stock ported heads will not be an issue.
Rich
Mikes 1994 z28
Oct 10, 2015 07:55 AM
autoxr166
Sep 25, 2015 04:21 PM
alliance12364
Sep 17, 2015 08:43 AM
Fatdog2
Sep 16, 2015 11:04 PM
Sep 11, 2015 09:44 AM
