Doing an oil change, first time on my baby
Originally posted by 96LT14u2Nv
it is up to u. any brand of 5w30 or 10w-30 will do just fine.
i use a AC delco filter (part # PF25)
I work at a quick lube and change about 50 cars a day.My 1995 TA is about the easiest car ever to do. I use rottela T for turboe diesel trucks but i have many many mods including nitrous this oil is so thick you would think it would slow do the pistons
but it is a very high quality oil that hardly breaks down after 3000 miles. if you have very littl moods i would use mobil 1 10w 30 synthetic a little more than what u need but more protection can NEVER EVER HURT!!!!
hey guys, two more questions. First one, exactly how much oil do I put into it? The car is up on jack stands as we speak. Also, does anyone here have the links to the owners manual and the parts catalog? I lost them when I restarted my comp and had to reboot everything, thx.
Your LT-1 uses 5 qts of oil.
I use the PureOne oil filters by Puroilater.
If you only have the front end jacked up, so the car looks like its doing a wheel stand, you're leaving a bunch of oil in the pan. You wouldnt need to add 5 qts in that case.
Wrong thread sowwy
