doing Lt4 hot cam ????
Old Jan 31, 2006 | 08:11 PM
jkucz31's Avatar
im puting the lt4 hot cam in my 94 Lt1. what do i need for it to be completed and run good i ordered the hot cam kit and then ordered all the gaskets for the job. I got everything through jason cromer. do i need to program the computer. i already have a street tune on it from madz28. do i need a knock module or somthing
Old Jan 31, 2006 | 08:16 PM
Steve0's Avatar
Re: doing Lt4 hot cam ????
Contact a tunder, either madz28 or pcm4less and you should be able to update your tune to one for a LT4 hotcam. If you got the email package from madz28.com I think you may be able to make the upgrade for free.
You dont need a LT4 knock module, but it wouldnt hurt to have. It will only help you if you are getting false knock.
Old Jan 31, 2006 | 08:34 PM
Evil Eric's Avatar
Coolant, oil, gaskets, assembly lube, RTV silicone, new timing chain.
Old Feb 1, 2006 | 08:01 PM
jkucz31's Avatar
is that everything i need to do the install
Old Feb 1, 2006 | 10:11 PM
Sweetred95ta's Avatar
Lt4 knock module is recommended because of the roller rockers. They are quite louder than the stock rockers and have been known to produce false knock.
Old Feb 2, 2006 | 12:52 AM
cas0484's Avatar
how much did ya get the kit for from jason?
Old Feb 2, 2006 | 12:57 AM
94Z396_0621's Avatar
A stall conveter to make it launch better with the LT4 Hot Cam.
Old Feb 3, 2006 | 11:26 AM
jkucz31's Avatar
i got the kit and all the gaskets for roughly 612 shipped
Old Feb 3, 2006 | 12:13 PM
I went 12.8's without a stall and 12.28 with one. That was with the hotcam and all motor.
Old Feb 3, 2006 | 12:23 PM
WhyHelloOfficer's Avatar
That is extremely re-assuring.
I've got the LT4 Hotcam with a fully rebuilt 4L60E and Vigi 3000 stall (and all the other typical bolt-ons plus tune). I wasn't going to set my expectations too high, maybe a 12.90. With some MT ET Street Radials maybe a Mid 12 will be attainable.
One a side note to stay on topic:
When I did my LT4 Hot Cam Kit Swap I purchased the cam swap gasket set from Thunder (http://thunderracing.com/catalog/?ac...vid=4&pcid=157 -- scroll down to 'Gasket Packages') plus an OE Replacement Timing Set from the dealership. Honestly don't cheap out on this, and you might as well do it all while you've got it all torn apart.
Old Feb 4, 2006 | 10:32 AM
jkucz31's Avatar
i just bought my double roller timing chain for this as well. was going to go gear drive but oh well
Old Feb 4, 2006 | 11:42 AM
I wouldn't go off of my numbers. My car was a freak LT4 Hotcam car. One of the fastest I've heard with unported heads, even for ported heads.
Gear drives aren't the best over 6,000rpm. It's not recommended.
Old Feb 4, 2006 | 12:08 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I went 12.2 at 115 with my current setup. Hotcam, ported heads, forged 355 with 11:1 compression.
Old Feb 21, 2006 | 05:40 PM
cmaell2's Avatar
what gaskets did you need with the kit? I saw people saying they got the kit for 470 shipped...
Old Feb 21, 2006 | 05:52 PM
You could also install and electric water pump to free up alittle more horsepower.
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
