Doing lowering springs tommorow?
I was looking for a good install page or something on putting in these lowering springs I just bought. I did a search and didn't really find a good source for a 4th gen. I am putting in 2 inch Intrax lowering springs and KYB AGX adjustable gas shocks. Can anyone help me out? I did the Steeda lowering springs on my Mustang no problem, but I had instuctions. Thanks --------> Brad
i believe brent has one.
Could you maybe throw me a link? Not sure how to get to Brent's homepage. Thanks--------------> Brad
http://www.bfranker.badz28.com/fbody/guides.htm
He is the moderator here. His name is listed at the top of this forum just click it and it will take you to his profile with a link to his site.:) |
Yep he has one for a set of Eibachs with Hal shocks, its very confusing, if you don't have this, do this, ect...... Also the other link for a 4th gen spring install does not work.. Does anyone have something a little more informative about all shocks/struts. Thanks------------> Brad
Injuneer has this one. Might be of some help..
AustinZ28: Didn't I see another post where it looked like you just ordered shocks or do you already have them? There is no point in doing the springs if you don't have the shocks. The fronts are coil-over shocks and you would have to disassemble them all over again to put the springs on. |
OK I think I get the jist of what to do. Right now I cant afford an adjustable PHB (?) for the rear end or the relocation brackets for the LCAs (?) I think that is all I need to properly lower it?. Will it be alright to just put in the springs, shocks and get an alignment then wait a few weeks to install the other stuff mentioned above? --------> Brad
Originally posted by AustinZ28 OK I think I get the jist of what to do. Right now I cant afford an adjustable PHB (?) for the rear end or the relocation brackets for the LCAs (?) I think that is all I need to properly lower it?. Will it be alright to just put in the springs, shocks and get an alignment then wait a few weeks to install the other stuff mentioned above? --------> Brad |
It's really a straight forward job. Pick up a Haynes manual to assist you...everyone that works own their own car should have one to refer to. :thumb:
great guys thanks for the help. -------> Brad
Originally posted by shoebox Neither of those things are required for a lowered car-just recommended. So if I never get them, it won't effect anything? Will I be able to get an alignment with out them or will lowering eat my tires? -----Thanks -->Brad |
Originally posted by AustinZ28 So if I never get them, it won't effect anything? Will I be able to get an alignment with out them or will lowering eat my tires? -----Thanks -->Brad |
Thanks bro, you are truely appreciated around here. ---------> Brad
