does this vac hose go to the same place on a 96??(shoebox pic)
Old Sep 10, 2004 | 05:53 PM
97s10ondubs's Avatar
http://shbox.com/1/evap_sol.jpg
Ok see the upper hose? Says "to tb" well I have no hose going to the tb and the plastic "nipple" that comes off of EVAP solenoid is cut in half, that bottom hoes goes to a plastic sensor looking thing in front of it. Also I have a BBK tb, i dont have another vac hose port for it to fit on, the hose coming off the tb goes to the "plastic sensor looking thing" providing vacuum.
Old Sep 10, 2004 | 06:03 PM
Re: does this vac hose go to the same place on a 96??(shoebox pic)
This is why I hate buying used cars, they had the fuel regulator vac hose on the egr source and the vac hose from where the fuel reg source to the tb!! ****ing idiots I tell you. But anyways, are the vac lines still the same for 95's and 96's?
Old Sep 10, 2004 | 11:00 PM
The EEC purge vacuum lines are different, but shoud still connect to the TB port. The OBD-II (96/97) cars add a flow sensor, but it is in the line from the canister.
Compare the schematic for the 93-95 cars:
http://shbox.com/1/1995_evap.jpg
.... to the schematic for the 96/97 cars:
http://shbox.com/1/1996_evap.jpg
.... to see if your lines are connected correctly. There should also be a vacuum diagram on your radiator cover.
Old Sep 11, 2004 | 12:22 AM
Yea cool I got everything hooked up like that, ill check the rad cover, I didnt know that was there, thanks though.
Magenta_Hearts
Mar 29, 2017 08:54 PM
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
Mar 13, 2016 03:39 PM
Jlo
Feb 3, 2015 09:41 PM
