Does it matter if the headers you use do not have D Port flanges?
Old Dec 12, 2006 | 07:21 PM
tagz's Avatar
How crucial is it that the exhaust ports are matched? I am lookin to do a turbo set up, and i don't wanna spend top dollar for a set of headers i'm going to chop up. I can get a pair of SBC headers for 99 bucks but they have a round hole in the flange as opposed to the D port that is on the engine. Does it really matter?
Old Dec 12, 2006 | 08:26 PM
Rowan212's Avatar
i was wondering this as well ..
Old Dec 12, 2006 | 08:29 PM
my94blackz's Avatar
Find a set of damaged/unuseable headers and chop the flanges off and weld them to the set you want.
Old Dec 12, 2006 | 09:26 PM
2000GTP's Avatar
I would think there would be some sealing issues due to the mismatched ports possibly even leading to exhaust leaks.
Old Dec 12, 2006 | 09:29 PM
95LT1conv's Avatar
they will most likely leak. the previous owner of my car installed sbc hooker super comp shorties and no matter what i did i could not get them to seal properly
Old Dec 12, 2006 | 10:51 PM
Mikes 1994 z28's Avatar
Are you sure they will fit your car? If you dont know then I'd say they probibly wont... there is not much space between the fender walls and the headers on 4th gens. But on the same token... if they dont fit what the heck buy them anyways... sounds like a deal where you can make your money back on eBay. Just make sure you have a lead on a proper fitting header before you start the project otherwise you will waste a lot of time. I say buy them and let us know how it works out. As far as HP is concerned im not sure but IMO they will create turbulance right as the exuast exits the heads. Will it help scavanging? Probibly not if the aftermarket isnt doing it... and they throw tons of money at designing proper headers. Will they be better then stock though... hell yeah, but probibly not as good as d-ports. Its up to you if you think $9X.00 is worth a 14 hour job installing headers on a lt1 or spend some extra cash on d ports. Either or will net you good HP.
EDIT: just saw you were going for a turbo set up... probibly should move this thread to forced induction.
Old Dec 12, 2006 | 11:17 PM
RedRyder518's Avatar
I don't think it would matter as a few headers are not D-port headers, like RK Sport...
Old Dec 13, 2006 | 01:56 AM
BMoney's Avatar
I have a set of Hooker LT's and they are not D shaped!
Old Dec 13, 2006 | 05:34 AM
rskrause's Avatar
Moderator
As long as the opening into the header flange is larger than the port and there is enough surface to get a gasket seal it should work fine.
Rich
Old Dec 13, 2006 | 06:39 AM
rickyzZ28's Avatar
The headers I used on my LT1 swap are not D port shapped, because with the swap I can not use LT1 headers. Mine are for a L98 car. They do not leak one bit and I am running the Fel-pro gaskets on it.
Noenav
Mar 1, 2019 07:38 AM
Dmonty
Jun 2, 2015 11:19 PM
4586
Apr 29, 2015 01:43 PM
Drtryder
Apr 22, 2015 04:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
