Does it mater where the sprockets are?
Old May 30, 2003 | 01:40 PM
Rico's Avatar
Just putting the opti back on, not sure where the cars cylinders are but as long as I put the cam pin threw the sproket and put the pin in the correct groove, tooth thing on the opti I will have no problem right?
Just checking.
Old May 30, 2003 | 02:48 PM
Rico's Avatar
Anyone?????
Old May 30, 2003 | 02:52 PM
You just need to make sure the cam dowel pin goes into the correct hole in the Opti. One of the three holes is "different". Do not force it into the other two. Also, if you did cam swap, check the length of the dowel pin before you put the Opti on.
Old May 30, 2003 | 02:55 PM
Rico's Avatar
Old May 30, 2003 | 03:12 PM
thewinner's Avatar
you did line the dots up on the sprockets right?
Old May 30, 2003 | 03:21 PM
Rico's Avatar
Yes but I don't know where the pistons are should I ??? or as long as the dots are together it doesn't mater???
Old May 30, 2003 | 04:01 PM
If you lined up the gear dots, you're good.
If you put the dowel in the correct slot on the opti drive, you're good. It does not matter if you moved the timing gears after you put them on, lined up correctly. The opti does not care where the pin is, as long as it goes in the correctl slot.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
Queens94z28
Dec 20, 2014 09:11 PM
ChvyCruzen
Jun 22, 2003 05:59 PM
Javier97Z28
Apr 13, 2003 06:20 PM
