Top dead center / timing mark question...
Old Apr 13, 2003 | 11:14 AM
Javier97Z28's Avatar
Moderator
Please help me out real quick guys.. I'm nervous about doing this right even though my friends have told me I'm all set 103249872134 times...
I'm in the process of a cam install and have the cam in and the timing set back on. When the timing set was off I moved the crank by mistake when taking off the crank sprocket with the puller.
Anywho, we took out the #1 spark plug and when the #1 piston came back up (compression stroke) the crank sprocket was at 12 o'clock. We then installed the cam gear at 6 o'clock with the chain..
So when piston #1 was at the top, the crank sprocket was at 12 o'clock and the cam sprocket was at 6 o'clock.
Does this sound OK? I want to confirm before I put my opti back on.
Thanks!
Old Apr 13, 2003 | 11:53 AM
Mikey97Z's Avatar
When the dots line up, the engine is at #6 firing position. I don't know what cyl #1 would be doing at that moment. Maybe the opposite? (end of exhaust stroke?)
Old Apr 13, 2003 | 12:46 PM
Moderator
Right.. both #1 and #6 should be up.. i think #1 would be at the end of it's exhaust stroke.. right?
Old Apr 13, 2003 | 03:35 PM
Moderator
sorry to ttt so early, i'm just working on this right now :/
Old Apr 13, 2003 | 03:45 PM
If you are looking at the crank gear and the dot is at 12, then you have nothing to worry about. The crank gear dot has to be correct because the gear is keyed to the crank (unlike the hub).
Crank dot 12, cam dot 6=#6 TDC and away you go! Line 'em up like that and you are fine.
Both dots 12=#1 TDC.
Old Apr 13, 2003 | 04:49 PM
Moderator
Rob you're just the one I was hoping would see this. You answering makes me feel 100% again..
Thanks man.. on a side note.. changing valve springs is a bitch
Smokn '94 Z's Avatar
Lightbulb
Exactly....
Old Apr 13, 2003 | 06:20 PM
Dave 96TA's Avatar
pardon us, Javier is drunk and installing valve springs
wait, or is that me...
ohhh the pain...the agony...no WAY I'm doing this on my car too
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Dec 7, 2014 11:32 AM
siguy
Nov 27, 2014 10:07 AM
