Does it hurt to run w/ just manifolds?
Old Jul 29, 2003 | 08:15 PM
kevmor99's Avatar
I heard this before and wasn't sure if it was true, does it hurt the engine any to run with just the exhaust manifolds on? (I don't have the rest done yet).
Old Jul 29, 2003 | 08:30 PM
Just the stock manifolds would be a little risky, IMO. Long tube headers are ok, but the stock manifolds are a little short. Just to see if it fires up, might be ok, but any extended time would not. Again, MHO.
Old Jul 29, 2003 | 08:58 PM
PatriotTA's Avatar
I agree with shoebox. I would be afraid of valve float running with open manifolds. Open y-pipe should be ok (or at least better) but I wouldn't run open manifolds.
Old Jul 29, 2003 | 11:00 PM
Donny O's Avatar
do you mean along the lines of needing back preasure or it running to lean or soemthing? like on old cars is you open the ehaust you need to re jet the carb also? fuel injected cars can compensate for that as long as you have the O2 sensors installed. i'm not sure if they are actually in the manifold or the y pipe as i've never tore mine apart.
as for what I think the others are telling you is that with the short manifolds you will be shooting fire out and could burn some wires or soemthing.
Old Jul 29, 2003 | 11:05 PM
96LT1TX's Avatar
what they are trying to say I think is that w/ the stock manifolds the collectors are too close to the engine and might burn some of the exterior parts of the motor up from the exhaust. If you've ever touched an exhaust pipe you know what I'm talking about (i have) they can melt wires together, or even completely destroy o2 sensors if they are near or whatever. Ive run straight shorties for a week or so, but I also wouldnt recommend that unless you have some major ear protection
Old Jul 29, 2003 | 11:06 PM
1994CamaroZ28's Avatar
Flames not what matters without having enough pipe like a long tube you run the risk on messing things up severly bent valves etc.
Old Jul 29, 2003 | 11:13 PM
kevmor99's Avatar
How does it cause valve float? (just wondering..) By not having backpressure on the valves?
Old Jul 29, 2003 | 11:14 PM
Donny O's Avatar
how would you bend a valve if you don't have enough pipe?
Old Jul 29, 2003 | 11:23 PM
Onetuffride's Avatar
Ok, I have a question on this same issue. I will be installing my AS&M Headers here this weekend, can I drive it about 4 blocks away to the muffler shop to get the exhaust attached to it. Will it suck a valve in that distance? Please let me know, I'm really curious.
Tuff.
Old Jul 29, 2003 | 11:32 PM
Nothing to do with valve float, IMO. That is a different matter. What I was concerned about was a lean condition because of the lack of pipe length that would cause a burned valve.
Old Jul 29, 2003 | 11:45 PM
bad95z28's Avatar
Ditto........
Old Jul 29, 2003 | 11:48 PM
Shoebox is right ,
one question though say it was overly cold outside and you were running strait manifolds when you shut off the engine it would suck the cold air in the motor would it not?
Old Jul 30, 2003 | 01:57 AM
kevmor99's Avatar
Is the lean condition/burned valve caused by cooler air?
Old Jul 30, 2003 | 08:13 AM
It is caused by the extra oxygen that is available to burn. That causes excessive heat. There is still some burning of the mixture going on when the exhaust exits the head.
Old Jul 30, 2003 | 09:29 AM
dobe's Avatar
long time ago i cranked mine up and ran i for a second if that.. out the manifolds
but i wouldnt recommend doing it
DirtyDaveW
Dec 1, 2016 05:37 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
