Does the cam spin twice during a complete engine revolution?
Old Jun 30, 2003 | 02:26 PM
BradZ28's Avatar
I recently installed a new timing chain after a break and after the installation of the new one the car would run (barely) but only with alot of gas! I'm wondering if I installed the timing chain right. The dots lined up but I'm wondering if maybe either the cam pulley or crank pulley was off 180 degrees? If one of the timing gears spins twice while the other spins once I may have messed that up. None of my valves were damaged but I did have a badly bent pushrod......all the plug wires were correct. Can anyone help? Why was she running so poorly?
Brad
Old Jun 30, 2003 | 02:28 PM
Highlander's Avatar
if you aligned the dots.. the problem lies elsewhere.. and the cam spins at 1/2 the crankshaft...
Old Jun 30, 2003 | 02:49 PM
BradZ28's Avatar
Thanx....
If the cam spins at half the crankshaft then at one point the cam dot is at 12 o'clock and the crank gear is at 12 o'clock (#1 at TDC I beleive) if this was so when the chain broke the if I left the crank gear at 12 o'clock but manually spun the cam gear to 6 o'clock (where the dots are next to each other) wouldn't the valvetrain be off a half rotation?
Old Jun 30, 2003 | 02:51 PM
Highlander's Avatar
The dots should be NEXT to each other.. the cam in 6 o clock and the crank at 12 o'clock...
Old Jun 30, 2003 | 02:53 PM
BradZ28's Avatar
That I know, but at one point both dots are at 12 o'clock, correct?
Originally posted by BradZ28
Thanx....
No, you're not hurting anything. You are merely re-synchronizing it. They can both be at 12 or crank 12, cam 6. Same result.
Old Jun 30, 2003 | 03:06 PM
InjectedSS's Avatar
YES that is correct! when BOTH dots are at 12 o'clock that would indicate the car is on the #1 firing order
Old Jun 30, 2003 | 03:07 PM
BradZ28's Avatar
I see.....once again I am humbled by your knowledge
Thanx
Noenav
Mar 1, 2019 07:38 AM
Killer94z
Jan 13, 2015 12:06 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Ricardo
Nov 29, 2014 10:58 AM
