Does a burned plug wire also kill an Opti?
Old Jul 24, 2008 | 11:04 AM
derrickgott007's Avatar
I have a burned plug wire. I can hear it arching out onto the header plain as day. Yes that is causing a miss. My question is that I heard that if you burn a plug wire that it also causes a burned hole or a burned spot in the opti. Should I go ahead and replace the opti while I do new plugs and wires?
It's a 97 Z-28.
Old Jul 24, 2008 | 03:27 PM
marshall93z's Avatar
Doubtful.
Old Jul 24, 2008 | 03:59 PM
moparman's Avatar
My car has burned a wire or two and never caused a problem with the opti. Just replace the wire.
Old Jul 24, 2008 | 05:07 PM
This has probably been asked to death, but what are the best plugs and wires to use? Should I use the 100,000 mile GM ones? Or should I use Bosch platinum plugs with the 4 electrode things?
Which wires are best? I saw a set on the MSD website that were 8.5mm and they were red, but they were all 12" long. Isn't that a little short for the back cylinders? It's what they reccomend for a 97 Z28. And is $100 a little steep for just wires?
Old Jul 24, 2008 | 05:40 PM
slomarao's Avatar
NGK or autolite for plugs. I have msd wires but many companies will work fine. I would never put anything but an ngk or autolite plug in a LT1 engine.
But thats just me. Others may tell you differnet.
Old Jul 25, 2008 | 01:59 AM
97SS0594's Avatar
NGKTR6 NGKTR6 NGKTR6 NGKTR6 NGKTR6 NGKTR6 NGKTR6 NGKTR6 NGKTR6 NGKTR6 NGKTR6 NGKTR6 NGKTR6 NGKTR6
and i like my taylor wires
grabbem88
Mar 18, 2015 01:25 PM
grgguy
17
Feb 23, 2015 07:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Alex Barnes
Jan 24, 2015 10:21 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
