does this bearing look bad?
Old Jun 15, 2008 | 08:59 PM
luckyou03's Avatar
ok I just had this engine rebuild 15k miles ago and I'm been getting fuel in my oil tank and it's been running bad for about 800-1000 miles. I've been told that fluid in the oil tank will destroy rings and bearings. Well I did a leak down test and my rings seem fine and hold pressure but I just pulled the cam out and saw this bearing. The cam looks perfect. No scratches or anything. I can catch my fingernail in the scratch in the bearing. Am I overreacting or do I need to have my motor rebuild again?
Old Jun 15, 2008 | 10:22 PM
FryedClutch's Avatar
id change the cam bearings
no sense and putting it back together just to wonder if its gonna hold or not when you can spend maybe a hundred bucks and not have to worry
plus if you can feel it with your nail it almost def has to be replaced
Old Jun 15, 2008 | 10:48 PM
Just the front bearing is fairly easily replaced. If the others are like that, you have to pull the engine to replace them.
Old Jun 15, 2008 | 11:19 PM
luckyou03's Avatar
I see scratches similar on the second bearing. If I'm pulling the engine I might as well replace all the bearings right?
Old Jun 16, 2008 | 01:39 AM
sbs's Avatar
sbs
Absolutely. Cost of bearings is small compared to cost of labor and cost of things that ride on the bearings.
Old Jun 16, 2008 | 02:21 AM
luckyou03's Avatar
nuff said thanks
Old Jun 16, 2008 | 02:27 AM
MachinistOne's Avatar
That bearing is pretty worn for only 15K miles, and those scratches indicate dirty assembly practices, not gas in the oil.
grabbem88
20
Dec 27, 2015 07:42 PM
SergheiS
May 16, 2015 12:12 AM
KYWes
Apr 15, 2015 07:28 PM
carl.froehlich
Mar 13, 2015 12:38 AM
chuyz28
Nov 25, 2014 11:14 PM
