Does adding trans cooler add fluid capacity
Old Oct 19, 2003 | 02:28 PM
CheshireCat's Avatar
Question Does adding trans cooler add fluid capacity
I'm installing a transmission cooler and I want to know if the addition of the cooler increases the capacity of transmission fluid. I have read through Brent94Z's guide to installing the cooler
http://www.bfranker.badz28.com/94Z/trannycooler.htm
and I must say it has been extreemly helpful. Thanks Brent!!!
Brent didn't indicate that he added fluid to compensate for the cooler, so I assume I won't need to do so. That being said, it just seems intuitive that I will need to add more transmission fluid. If anyone can clarify this for me, I'd appreciate it.
Thanks again for your advice!
Old Oct 19, 2003 | 02:39 PM
Robert95z's Avatar
Only reason you would need to add more fluid is when you disconnect the lines and some atf drains out. I dont remember adding ANY atf when i put my cooler in.
-Robert
Old Oct 19, 2003 | 02:43 PM
jasons93z's Avatar
YES, It does add fluid. I had an a4 in my 93 and i installed a cooler on it. And i had to add about 3/4 quarts.
Old Oct 19, 2003 | 02:51 PM
I guess the only sure way to know will be to install the cooler then run through the process of checking the fluid level when hot... I would think it will need about as much fluid as the cooler would contain. But then what I think is frequently wrong... That's why I ask...
Thanks again,
Old Oct 19, 2003 | 03:38 PM
TedH's Avatar
It will increase the amount of fluid by the amout of additional capacity of the added plumbing.
Old Oct 19, 2003 | 04:21 PM
TreySpeed's Avatar
On permanent vacation
i needed about 1/2 qrt of ATF for my truck when i added my 30,000 GVW cooler
james007moore
Jan 1, 2016 01:14 PM
PCLZ28
Dec 24, 2015 05:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 12, 2014 10:51 PM
guionM
13
Sep 5, 2002 09:58 PM
