Do you bleed the ABS when bleeding the brakes
Old Oct 19, 2003 | 12:29 PM
94foormula's Avatar
When you guys bleed the brakes do you bleed the ABS. Ive heard people go both ways with this. Doesnt the fluid go through the ABS from the master cylinder anyway?
What have you guys done?
Old Oct 19, 2003 | 01:01 PM
OBE1 95Z28's Avatar
The GM manual tells you to bleed the ABS. Personally I don't bleed the ABS unless I have air in the system (i.e. let the reservoir run dry). If you want to bleed the ABS, there are 2 fittings that face forward on the module.
tnmotown
Aug 10, 2015 11:52 PM
MikeWhitener
Aug 2, 2015 06:17 PM
Boss002
Jul 24, 2015 10:47 AM
