How do you hook up emissions on passenger side LT?
Old Jul 1, 2003 | 02:57 PM
speed76demon's Avatar
On my jet hot lt's there is a hole in the back of the header to plug an emission pipe into. I'm assuming that this has to do with the air or something. Well anyway do i just cut the one off the manifold then stick it in the header if so will some gasket seal seal that tube good enough? any suggestions?
Old Jul 1, 2003 | 03:31 PM
SplitFire's Avatar
Are you talking about the hole to plug the o2 sensor into? Near where the header connects to the ypipe?
Old Jul 1, 2003 | 03:55 PM
no im talking about a metal tube that plugs into the back of the manifold
Old Jul 1, 2003 | 04:01 PM
TheHeadFL's Avatar
If you mean the one on the back on the passenger side, its the EGR tube.
Old Jul 1, 2003 | 04:29 PM
so do i just snip it and put it in my headers? Then put some sealer around it?
Old Jul 1, 2003 | 05:05 PM
anaik's Avatar
Why not just make a little plate to cover the hole in the header.
Old Oct 19, 2003 | 01:03 PM
bad96firechikin's Avatar
The thing unbolts from your stock exhaust manifold and bolts into the header. Not too difficult =\ I can't see why anyone would have a prob figuring this out.
Chet1185
May 10, 2015 09:24 AM
camaro98_speed
Apr 22, 2015 11:26 AM
alex5366
Feb 17, 2015 10:43 PM
